Suspension replacement - Defender Source
Old May 3rd, 2015, 10:15 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
I'm sure this has been answered, but the search function blows.
I have original stock springs and shocks on my D90. Shocks are pretty much done. I want to replace with new, and I want a small lift, but nothing too big that will make my stock tires look too small. I know nothing about where to start other than many people say go OME.
To keep a smooth ride, and add perhaps 1" lift, what springs/shocks do I need? I am confused as there seem to be a model for the front and rear.
Please help me with the part numbers that would best suit what I am looking for. Thanks in advance!
1994 Defender 90
2006 LR3 SE
1996 Discovery I (sold)
1991 Range Rover Classic (sold)
1995 Range Rover Classic (sold)
2006 LR3 SE (sold)
Old May 3rd, 2015, 10:28 PM
bjf's Avatar
bjf
barry f
94 ST #395
Why the lift? Especially with stock tires?
Old May 3rd, 2015, 10:30 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
I feel like my truck is sagging or sits lower than most stock ones. Maybe it's just the worn out shocks?
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old May 3rd, 2015, 10:35 PM
rovertrader's Avatar
rovertrader
Dale
If they are in fact original, I am sure she is sagging! For minimal to no lift, just go back original or OME to orig spec- it will sit at least an inch higher than she is currently...
Old May 3rd, 2015, 10:41 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
Shocks, good or bad, won't have any bearing on ride height. Since you're on the original springs, it's very possible that they're just worn out and sagging.
Most of the OME stuff is going to net you around 1.5" of lift. The 761/764 is a solid combo for most 'normal' applications.
-Ash
Geared Restoration Co.
352-572-3236
Old May 3rd, 2015, 11:04 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Originally Posted by Ash View Post
Shocks, good or bad, won't have any bearing on ride height. Since you're on the original springs, it's very possible that they're just worn out and sagging. Most of the OME stuff is going to net you around 1.5" of lift. The 761/764 is a solid combo for most 'normal' applications. -Ash
I see that the 761/764 is called "medium duty". For OME, will that be as close to stock height as possible?
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old May 3rd, 2015, 11:07 PM
bjf's Avatar
bjf
barry f
94 ST #395
Just go stock. It will sit better and be a decent ride.
My 110 was sagging like Briggs balls. Put some new genuine springs in and suddenly the truck was sitting high and tight (like my balls 15 years ago)
Old May 4th, 2015, 01:50 AM
Stock spring replacement with bilsteins will make a great improvement. For greater improvement replace bushings as well.
Old May 4th, 2015, 07:22 AM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Just go stock. It will sit better and be a decent ride. My 110 was sagging like Briggs balls. Put some new genuine springs in and suddenly the truck was sitting high and tight (like my balls 15 years ago)
Haha great analogy. Where would I find new Genuine springs/shocks? Dealer?
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old May 4th, 2015, 07:24 AM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
I just ejected all of my morning tea through my nose!
Old May 4th, 2015, 09:46 AM
bjf's Avatar
bjf
barry f
94 ST #395
Genuine shocks are trash.
Order Bilsteins or ome and get the springs from zack.
Old May 4th, 2015, 09:50 AM
rovertrader
Dale
Or Fox- better than the new Bilsteins...
Check out my new suspension Buckon37s Misc. Chit-Chat 25 June 2nd, 2004 03:13 PM
Suspension benh Defender Technical Discussions 30 February 17th, 2004 02:04 PM
Rear Suspension Question dnewman9 Defender Technical Discussions 3 February 1st, 2004 06:31 PM
Suspension! TwisteD90 For Sale - Parts 11 January 14th, 2004 04:13 PM
OME suspension, and tires huntahdefender Defender Technical Discussions 4 October 10th, 2003 04:14 PM
