Suspension Question (swap from my RRC to the 90) - Defender Source
Old January 11th, 2008, 04:17 PM
AggieD90's Avatar
AggieD90
Kevin Collins
'95 AA Yellow & '97 Willow Green
So I had a brain fart and was going over the stuff that will be happening with the 90 and started thinking about cannibalizing the Classic for its suspension.
The 90 has the typical OME HD front and back setup (spring and shocks).
The Classic has a Pre 3-Link Stage III setup on it. I'm thinking everything is essentially the same. Can I put the SG suspension off the Classic on the 90 and take the OME setup and stock trailing arms and radius arms and use them on the Classic?
Old January 11th, 2008, 07:01 PM
Shane@EVS
Roverhybrids
yess
Old January 11th, 2008, 08:57 PM
AggieD90's Avatar
AggieD90
Kevin Collins
Good deal. It's really not necessary on the Classic and if I swap out the OME stuff on it then it will have the same road manners as the '95 Classic...which is a lot better. I don't mind the 90 being a little irrational to drive
Old January 14th, 2008, 07:27 PM
rgrrvr's Avatar
rgrrvr
DJ Menasco is The Dude
1995 D90
I swapped my 3rd link from my Disco onto my project D90, the years were different and the crossmember had holes in a different place but other than that it was straight forward. I also have extra arms if you need them front and rear, sway bars too.
Old January 15th, 2008, 09:47 AM
AggieD90's Avatar
AggieD90
Kevin Collins
Keith, I may enlist your help on this project. I figure I'll rebuild the shocks when I've got everything apart.
Old January 15th, 2008, 10:33 AM
rgrrvr's Avatar
rgrrvr
1995 D90
let me know, I'll be dragging the 90 to the monster garage to try and sort the wiring issues, hopefully someone there will have a clue about the tcase connections.
Old January 15th, 2008, 02:52 PM
AggieD90's Avatar
AggieD90
Kevin Collins
I think quite a few people are planning on coming so hopefully there will be. I'll bring the 90 but we can talk about the swap while we're there.
Old January 15th, 2008, 07:29 PM
rgrrvr's Avatar
rgrrvr
1995 D90
I can show you the differences I found
NAS 90 Frame Swap with a budget SafariHP Truck Build-up's & Restores 50 September 30th, 2010 12:12 PM
Another Suspension Question mdmccallum Defender Technical Discussions 25 September 5th, 2007 11:21 AM
Another suspension question Joe P Defender Technical Discussions 1 March 15th, 2005 02:30 PM
suspension question - Scorpion asator Defender Technical Discussions 25 October 10th, 2004 12:24 PM
Rear Suspension Question dnewman9 Defender Technical Discussions 3 February 1st, 2004 06:31 PM
» Defender Registry
Watson
80sailor
#304
TRS
Add your Defender
