Suspension question, opinions welcome - Defender Source
Old July 23rd, 2011, 03:49 PM
Slick62
Kevin
94 Defender 90
Unhappy Suspension question, opinions welcome
I have had my Defender for 4 years, it came with air suspension, attached compressor, gauges ect. The system doesnt hold air. I have tried/sort of fixed it a few times, found the leak, tightened the nut replaced the rubber washer. But in a couple weeks its broke again, I dont know exactly whats on there, they are yellow with no serial numbers, the compressor is ARB and the gauges are Rancho
I am done with it, I don't do any crazy offroading, and just want to put on some gas shocks. So it handles better on the road.
- What do all the cool kids do for shocks, as far as brand name? OME, Bilstien, Rancho. Are these TerraFirma things, any good?
- What do I need to consider when I buy new ones, I have an ARB bumber with winch and a 1 - 1.5 inch lift (I think)
- Do I need to replace the springs too? or can I just do the shocks and do the springs later if needed?
Thanks for looking and your opinion/advice. If anybody is in the Denver area and wants to look at it for me, that would be appreciated too.
Kev
Old July 23rd, 2011, 04:35 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Don't know the nitty gritty of springs and shocks. Usually you want to out of good habit change both springs and shocks at the same time. There are a few guys on here that have been using terrafirma w/good results. Old man emu is a brand I am familiar with and hold up pretty well.
Old July 23rd, 2011, 04:37 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Clarification- As someone with an AirRide suspension on my 110 (it is basically fool proof and never has failed in 8 years). My system has no springs - only shocks and airbags. It sounds like you have springs? Anyway, you need to let us know tire size and then you will hear all sorts of combinations of springs and shocks.
____________________
Chris Hinkle
Current project - D110 with extended cab and LS3
Old July 25th, 2011, 01:57 PM
Defender90_218's Avatar
Defender90_218
Trenton Smith
1997 D90
Wait, is this the Defender with the Air Suspension that was in LRO some years back?
Old July 25th, 2011, 02:11 PM
Sounds more like you have the Rancho adjustable shock system, not an air-ride system. The Rancho system has it's own compressor. The ARB compressor should be for your ARB lockers.
Try cutting off the end of the air line and re-seating them. Use some soapy water in a spray bottle to find the leaking connection.
Old July 25th, 2011, 02:49 PM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Originally Posted by Slick62 View Post
- What do all the cool kids do for shocks, as far as brand name? .
Kev
I think the cool kids use http://www.kingshocks.com/
Not being one of them, I use Rancho 9000s
Old July 26th, 2011, 12:31 AM
Slick62
Kevin
94 Defender 90
Yes they are air shocks,
OME Suspension Upgrade - Question about rear sprongs DNinety Defender Technical Discussions 12 December 9th, 2010 08:20 AM
Another Suspension Question mdmccallum Defender Technical Discussions 25 September 5th, 2007 11:21 AM
Another suspension question Joe P Defender Technical Discussions 1 March 15th, 2005 02:30 PM
suspension question - Scorpion asator Defender Technical Discussions 25 October 10th, 2004 12:24 PM
Rear Suspension Question dnewman9 Defender Technical Discussions 3 February 1st, 2004 06:31 PM
