Suspension question/advice - Defender Source
Old July 8th, 2013, 10:05 PM
Trooper90
John Capps
1986 ninety
Hey guys I'm about to order a suspension kit for my ex-mod.pretty sure I know what I want but wanted to check with you guys. I'm looking at Rovers North's Terrafirma pro sport hd kit,and their return to center steering damper. Is this an okay set up?
My uses are light wheeling and currently no winch. Mostly wondering about the damper?
Old July 8th, 2013, 10:09 PM
I can't see any point to a return to center damper beyond hiding problems in the front end.
As to the suspension, what are goals and why do you want to change from the stock suspension?
Old July 8th, 2013, 10:16 PM
Trooper90
John Capps
1986 ninety
Just wanting to kinda update the truck and have come to suspension. I didn't understand the return to center either, just curious about that.
What is on the truck now is old, maybe original, and just figured that I'd change it so that I would know what I have.
Old July 8th, 2013, 10:18 PM
Ray_G's Avatar
Ray_G
Ray Gerber
I would go OME or even LR HD over TF. (having done all three...there is a reason I got rid of the TF after a year).
Old July 8th, 2013, 10:34 PM
Trooper90
John Capps
1986 ninety
So if I go with the OME shocks,they will work with my stock springs? Thanks
Old July 8th, 2013, 10:41 PM
Have you considered a mild lift? Although there is some additional cost in going with a lift, it might be worth it if you're going with new springs.
Old July 8th, 2013, 10:45 PM
Trooper90
John Capps
1986 ninety
Yes I'm open to that, want to run 7.50x16's.(have 9 of them) what would you suggest?
Old July 8th, 2013, 11:25 PM
Ex Mod trucks have fairly heavy duty springs which give a slight lift over standard. Stock woodhead shocks (the black ones) are pretty good units if not leaking or rusted out. Same goes for steering dampers.
IF IT AIN'T BROKE, don't fix it. If your shocks (or damper) are bad, just replace them. No need for any lift springs with 7.50x16.
Plenty more on an ex mod to upgrade before mucking about with the suspension. Seats for one.
Old July 9th, 2013, 12:19 AM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
I like my Terra Firma Pro Sport set up, but I have heard nothing but good about OME as well. On my last truck (an ExMoD 90) I had a Pro Comp 2" Standard Duty kit from RN and for what I used it for (a cooler of beer and some chicks) it worked really well.
Front Suspension Buckon37s Misc. Chit-Chat 17 November 27th, 2006 01:02 AM
Rear Suspension Buckon37s For Sale - Parts 5 October 10th, 2005 10:58 AM
OME suspension id kolvedic Defender Technical Discussions 1 August 15th, 2005 01:46 PM
Semi-racing suspension Doug Defender Technical Discussions 10 July 22nd, 2005 12:26 AM
suspension question - Scorpion asator Defender Technical Discussions 25 October 10th, 2004 12:24 PM
