Suspension or Body lift - Defender Source
Old October 1st, 2016, 11:27 PM
Mojo's Avatar
Mojo
Aaron Norton
1994 Defender 90
How can you tell the difference from a body lift or a suspension lift on a NAS Defender?
Old October 1st, 2016, 11:35 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
The body is bolted to the frame, component by component. There is no body lift. Just suspension lift.
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2516
As in what to look for or will others notice?
"Barry is correct!"
Old October 1st, 2016, 11:37 PM
Mojo's Avatar
Mojo
Aaron Norton
1994 Defender 90
What to look for
Old October 1st, 2016, 11:47 PM
D90Overkill
David Frank
1995 ST #2516
It'll look a little silly ;-) Look for lift blocks. Essentially poly spacers between the frame and the body. You'll see way more shock tower up front and more distance between the spring perch and tub wells than usual.
"Barry is correct!"
Old October 1st, 2016, 11:51 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
You can't do this on a NAS D90! Or at least very difficult. Look at how bulkhead attaches. I should qualify that anything is possible, but it is so rare and totally custom I don't think it applies. But yes, if there is a will... So look for spacers, but I've never seen a NAS so chopped.
Old October 1st, 2016, 11:56 PM
D90Overkill
David Frank
1995 ST #2516
I'll defer to Davis' opinion as I've never swapped my bulkhead. My research was a while back, and on ROW 90's, although I don't know how the bulkhead boltings would differ. Here's a look for ya. I don't recommend it ;-) Just click on "more details" for the list of components needed for this effect.
http://www.mm-4x4.com/5-super-lift-k...ver-3485-p.asp
"Barry is correct!"
Old October 2nd, 2016, 12:42 AM
Landy_Andy's Avatar
Landy_Andy
Andy
NAS, ROW... 90 or 110 there all bolted on the same. Two large bolts (one each side) at the bottom of the bulkhead leg into the front out riggers. 2" (suspension) lift is most common, 3" & 4" tends to be used when running 35" tires and when linking the suspension due to the packaging constraints the frame and drive line force you into.
Old October 2nd, 2016, 12:51 AM
D90Overkill
David Frank
1995 ST #2516
Originally Posted by Landy_Andy View Post
NAS, ROW... 90 or 110 they're all bolted on the same.
Although that's what I figured, I'm hardly an expert on any of this, just an aficionado. I either tinker with it, or drink a beer and stare at it for a while ;-)
"Barry is correct!"
Old October 2nd, 2016, 07:44 AM
Originally Posted by D90Overkill View Post
I'll defer to Davis' opinion as I've never swapped my bulkhead. My research was a while back, and on ROW 90's, although I don't know how the bulkhead boltings would differ. Here's a look for ya. I don't recommend it ;-) Just click on "more details" for the list of components needed for this effect. http://www.mm-4x4.com/5-super-lift-k...ver-3485-p.asp
That link is a suspension lift. It would be very hard to do a body lift and it could not be made to look right.
Old October 2nd, 2016, 10:00 AM
D90Overkill
David Frank
1995 ST #2516
It's a 3" suspension lift with a 2" body lift as well. Lift blocks are in the middle of the list of components.
ID:	158877   Click image for larger version
"Barry is correct!"
Old October 2nd, 2016, 10:22 AM
D90Overkill
David Frank
1995 ST #2516
There ya go. I knew somebody would know. I guess it's nothing like a body lift on a classic. Back to the op question: Look for those spring spacers! ;-)
Not the below pictured body lift spacers like on other rovers.
ID:	158879   Click image for larger version
"Barry is correct!"
Old October 2nd, 2016, 10:47 AM
Mojo's Avatar
Mojo
Aaron Norton
1994 Defender 90
Thank you
RRC air suspension valve body/compressor assembly $50 J. Pound For Sale - Parts 1 March 16th, 2016 04:14 PM
Suspension upgrade, no lift toona Defender Technical Discussions 22 April 9th, 2015 03:52 PM
Suspension lift??? Clarky199 Defender Technical Discussions 21 December 16th, 2014 08:20 AM
Body Lift LRover Defender Technical Discussions 3 May 27th, 2011 04:25 PM
Old Man Emu Lift and Suspension kit TravelerBT Wanted 7 November 14th, 2008 12:07 PM
