Suspension lift??? - Defender Source
Old December 4th, 2014, 04:17 AM
Clarky199's Avatar
Clarky199
Louis
1989 defender 110 hard top
Suspension lift???
I'm debating lifting my defender 110 by 2 inches but really don't know if it's going to be worth it, can anyone offer any advice? I do a fair bit of off roading working on a farm and towing trailers so a lift seems like a good idea as the cattle are really churning up the ground but will I need to change anything on the car, break lines ect ect ect?
Old December 4th, 2014, 05:34 AM
BostonAndy's Avatar
BostonAndy
Andrew
Moose :: 1985 110
When I took delivery of my 110 I swapped out the completely shot suspension for an Old Man Emu Heavy duty kit. Truck drives great and the lift (1.5") is a great look.
Old December 4th, 2014, 06:00 AM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
Old man emu on my 110 too. It's supposed to be heavy duty medium. It raise the vehicle 1,5-2 inches. The ride's a bit hard unladen but takes the curve like a sport car!
Old December 4th, 2014, 07:24 AM
Clarky199's Avatar
Clarky199
Louis
Does it need any modifications to fit though? What about extending the break lines and things. That's what's worrying me!
Old December 4th, 2014, 07:27 AM
DannyboyUpstate's Avatar
DannyboyUpstate
Danny Harrington
1983 110 3-door
Also interested in people's experiences.
Old December 4th, 2014, 07:36 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Yes, you should extend the brake lines.
Call Lucky8 and have them pull a kit together for you based on what you plan to do with the truck. You get what you pay for in this area so proceed with caution. A proper system should last you for 10-15 years. The wrong system may not get you out of the barn.
Do it right the first time.
Clay
Old December 4th, 2014, 07:41 AM
Clarky199's Avatar
Clarky199
Louis
I really appreciate that clay, thanks for the honesty. Money is tight but you are dead right, looking back I guess the defender does put up with a lot of abuse on the farm. I may as well go all out on it and spend the money to make it last!!!
Old December 4th, 2014, 08:13 AM
1of40's Avatar
1of40
1of40
Glad you took that advice the right way. After you do your due diligence and figure out what set up and brand to best go with it never hurts to post here in the wanted section and look in the for sale parts section. You might have some Rover luck and find most or all of what you need and save a few bucks. It happens. But only if you know what you are looking for and have a gauge on what it's worth beforehand.
Clay
Old December 4th, 2014, 08:15 AM
If you don't change the shocks for longer ones, you won't need to do anything with the brake lines! Longer springs don't change how far the wheels go uppy-downy. They only change the normal ride height of the vehicle.
Old December 4th, 2014, 08:50 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Lifting the truck won't do anything for you if the issue is farm animals churning up the ground. Your axles aren't going to get any more clearance with a lift. Maybe slightly more aggressive tires or even slightly taller and skinnier.
That being said, having a lift is nice, and new shocks and springs are always a plus.
Old December 4th, 2014, 09:23 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
By keeping it stock or by using OME medium springs with matching shocks (OME, Bilstein, etc.), you will not have to worry about the complications that manifest with higher lifts. Those gremlins take time and money to chase.
Old December 4th, 2014, 10:36 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
The point of a lift, IMO, is to gain ground clearance and wheel opening clearance to run larger tires. If you want these things then the lift is worth it. If you don't want these things then don't bother, just get some new shocks.
Also, I'm of the opinion that lifted vehicles running stock size tires looks downright silly. New larger tires will run about another $1000 so you'll want to factor that into the equation.
Old December 4th, 2014, 10:39 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I'm not sure what you mean....
Old December 4th, 2014, 10:40 AM
DannyboyUpstate
Danny Harrington
1983 110 3-door
LOL Good stuff
Old December 4th, 2014, 10:52 AM
Louis
Are you in Buckinghamshire ?
In my experience a 2 inch longer spring will not require a longer brake line but the 2 inch longer Goodrich ones that are far superior to oem are only 25quid with free carriage.
http://www.paddockspares.com/slr0106...us-2-inch.html
Stay away from Britpart shocks and springs. Their Super Gaz shocks are terrible.
Old December 4th, 2014, 11:30 AM
Clarky199's Avatar
Clarky199
Louis
Yeah I live in Aylesbury, do you know it?
Old December 4th, 2014, 11:51 AM
skygrip's Avatar
skygrip
Claude
110 CSW 1991
May be Portal axles from à Volvo C303 will give you more than 5 inch lift...
Old December 4th, 2014, 03:09 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
Never had any problems with the brake piping. The u joint seems to suffer a bit as I renew them annually ..
Old December 4th, 2014, 03:10 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
what kind of lift do you have that you're replacing u-joints annually? And what brand are you using...
Old December 16th, 2014, 08:57 AM
Urohof
Ur
Defender 110
Hi Everyone new to this forum and figuring out my suspension. Does anyone have some feedback on the Bilstein B6 ride control?
Old Man Emu Lift and Suspension kit TravelerBT Wanted 7 November 14th, 2008 01:07 PM
Suspension benh Defender Technical Discussions 30 February 17th, 2004 02:04 PM
Rear Suspension Question dnewman9 Defender Technical Discussions 3 February 1st, 2004 06:31 PM
Suspension! TwisteD90 For Sale - Parts 11 January 14th, 2004 04:13 PM
OME suspension, and tires huntahdefender Defender Technical Discussions 4 October 10th, 2003 04:14 PM
