Suspension bolt list - Defender Source
Old November 4th, 2011, 02:38 PM
I'd like to put together list of all nuts and bolts needed when doing a suspension refresh or upgrade, both for my own immediate needs, but to add it to the site so it will hopefully help others when their time comes. It seems crazy that this hasn't been documented before.
Here is what I think I need front to rear, all grade 8.
Panhard rod bushing ends - 2 x M14 x 80mm bolt with nylon insert nuts
Front bottom spring retaining bolts - 4 x 3/8" x 1" bolt with nylon insert nuts
Front radius arm bushing to axle - 4 x M16 x 100mm (5/8" x 4") bolt with nylon insert nuts
Front radius arm big nut - ??
Rear trailing arm big nut - ??
Rear trailing arm bushing to axle - 2 x M16 x 100mm (5/8" x 4") bolt with nylon insert nuts
Rear bottom spring retaining bolts - 4 x 3/8" x 1" bolt with nylon insert nuts
A-arm bushing to frame - 2 x M20 x 100 mm (3/4" x 4") bolt with nylon insert nuts
A-arm arms to center block - ??
Please let me know if you know the missing ones, or disagree on any of these.
thanks,
charles
Originally Posted by pendy
I'm here for the D's
Old November 4th, 2011, 03:23 PM
bjf's Avatar
bjf
barry f
94 ST #395
Since you are doing this I have a question, is it possible to change front shocks without removing the springs?
Old November 4th, 2011, 03:26 PM
I guess you could remove the shock tower cover, shock tower bolts, and the shock mounting bolts and remove the shock up via the engine compartment.
But let's keep this on topic. This thread is about bolt sizes!
Old November 4th, 2011, 03:27 PM
bjf's Avatar
bjf
barry f
94 ST #395
Fine so the answer is no.
Old November 4th, 2011, 03:30 PM
I just explained how to do it. How did you translate that into a no?
Old November 4th, 2011, 05:09 PM
bjf's Avatar
bjf
barry f
94 ST #395
Too much crap in the way
Old November 4th, 2011, 05:14 PM
Yes on mine one side is way too hard to get at - i didn't even remove the cover to get the shock out. I thought maybe you didn't want to remove the two retaining bolts or something (that's all that is holding your spring in other than the shock)
Old November 4th, 2011, 05:18 PM
bjf's Avatar
bjf
barry f
94 ST #395
Do I need a compressor?
Old November 4th, 2011, 05:21 PM
Yes, but not for this job.
Old November 4th, 2011, 05:50 PM
James Pierce's Avatar
James Pierce
James Pierce Jr.
Don't know if this will help but this is what you get when you order RN Genuine Suspension Busing Kits
RNK5915 Rear:
2 NY612042 - Nyloc Nut 3/4" UNF
2 NTC1772 - Bushing Bottom Link Rear
2 NTC1773 - Bushing Top Link ASSM
1 STC618 - Bushing Kit Trailing Link
2 NY120046 - Nyloc Nut M20
6 FS110306 - Bolt M10 x 30mm
6 NY110047L - Nyloc Nut M10
2 NY610041L - Nyloc Nut 5/8" UNF
2 BH610321L - Bolt 5/8" UNF
2 BH612321 - Bolt 3/4" x 4"
RNK 5916 Front:
2 ANR3410 - Panhard Bushing
4 NRC4514 - Bush Rear of Front Radius Arm
4 BH116207 - Bolt M16 x 100mm
4 NTC6781 - Bushing Radius Arm Front
2 BH114167 - Bolt M14 x 80mm
4 NY116051L - Nyloc Nut M16
2 NV114047 - Self Locking Nut M14
1 STC8008 - Lucas 5hp Air Compressor
Old November 4th, 2011, 06:39 PM
LOL. Yes this is a good list thanks. I went and ordered the standard versions since I wanted to get my order in and I didn't see any large metric grade 8 bolts on mcmaster (a quick look mind you). Hopefully they will work fine and I'll report back either way.
Old November 4th, 2011, 06:59 PM
NoVaKevin
Kevin
sold#1469
As a side note, I have found that Ace Hardware carries grade 8 in stock (at least the one near my parents house). Not sure how prices compares to McMaster, but if you need something on the quick then head to Ace. I spent about $40 for all nuts/bolts/washers for an SD type rack, with several to keep as spares. I wish I never sold my 90.
Old November 4th, 2011, 07:33 PM
jefferson's Avatar
jefferson
Jeff A
97 Defender 90 SW #593
I might be wrong, but I think for metric you want grade 10.9, which is the equivalent of SAE grade 8. Is this correct? I did some suspension work recently and went with metric 10.9.
Old November 4th, 2011, 07:34 PM
I hate to highjack but I had no issues doing the front shocks on my Defender?
Old November 4th, 2011, 09:40 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
That's because metric don't come in grade 8. Metric are generally class 8.8 or 10.9.
IIRC the nut on the end of the radius and trailing arms are 30mm and the A-arm to top link are 1/2" by something long. I have everything in the garage and will check tomorrow if no one has posted them.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old November 4th, 2011, 10:39 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Take in consideration that some of the metric bolts have the finer thread.
- Charles Eames
Old November 4th, 2011, 11:27 PM
Barry took it downhill already. No problem, we can make a new post or get it into the tech FAQ or substitute parts list.
I didn't have any issues either, but remember this is Barry asking. Why he's concerned about removing the spring is beyond me. He asked if it could be done and believe it can, although I wouldn't
Old November 5th, 2011, 12:10 AM
bjf's Avatar
bjf
barry f
94 ST #395
Oh I am not concerned but I was just curious if it could be done without removing the springs. When I did my 110 I replaced both but was trying to think if it was possible not to remove the springs. Sorry back on target
Old November 5th, 2011, 02:46 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Keep in mind that on some bolts, the actual threaded part of the shaft is longer than others. I can't remember which bolt I had trouble with because of this, but there was one I had to buy longer to get the correct clean shaft and cut the bolt. It could have just been the brand of bolts that McGuckins carried though--I thought it was the pan hard rod bolt that I had difficulty with... worth checking for you. You need to make sure that only the bare, non-threaded part of the bolt is what is in contact with any bushing and hangers.
Old November 5th, 2011, 09:38 PM
Yes you can remove shocks without doing springs. /end hijack
wiki
110 body Bolt size list? tomaco1 Defender Technical Discussions 5 April 9th, 2011 10:48 PM
Bolt List ajh Defender Technical Discussions 6 January 12th, 2009 11:21 PM
ss bolt kit installation question geneseemtn Defender Technical Discussions 2 December 4th, 2005 12:28 PM
Rear Suspension Buckon37s For Sale - Parts 5 October 10th, 2005 10:58 AM
