Suspension and wheel spacers - Defender Source
Old February 22nd, 2013, 07:27 AM
mightymo's Avatar
mightymo
matthew m
'95 Disco 300TDI
So its about time for Spring cleaning... or in my case "Spring-Truck-Projecting." I am currently running 285/70r16s on my stock wheels. I am getting some rubbing and turning radius is that of a tank. How well would wheel spacers help this problem?
Also I am running the suspension that was on the truck when I bought it (3" lift). The articulation is pretty poor. What type of suspension kits would help? I know a lot of folks use OME.. any other recommendations. Maybe take it down to a 2" lift? Thanks.
Old February 22nd, 2013, 07:57 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Yes spacers will give you a little more turning radius. As far as the articulation you need to start with figuring out what you have right now. What are the extended/retracted length of the shocks you have. What kind of springs are they. What is the height of your truck ground to center of axle on all four wheels on flat ground. Once you have this information you can figure out what is missing and figure out what you need to change. Remember the more articulation you get the more you are going to spend to get it.
Land Rover 110
Old February 22nd, 2013, 08:10 AM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
If you think your articulation is poor now just install the OME springs, you'll have even less articulation.
John C.
Old February 23rd, 2013, 01:44 AM
mightymo's Avatar
mightymo
matthew m
'95 Disco 300TDI
Thanks for breaking it down Barney-style for me. I will get the measurements and then try to plan it out... and hopefully without completely breaking the bank.
Old February 23rd, 2013, 08:07 AM
Capt Milks's Avatar
Capt Milks
Since you are in Charlottesville are you gong to the ROAV spring Rally? It is up at Wintergreen this year.
http://www.roav.org/
Land Rover 110
ac, wheel, wheel spacer
Steering Wheel Wobble aosias Defender Technical Discussions 15 March 2nd, 2014 12:29 AM
Does anyone have any experience with Toddco Suspension parts? fenwaystan Defender Technical Discussions 5 November 1st, 2009 11:17 AM
Clunk Clunk Clunk front wheel bjf Defender Technical Discussions 20 October 15th, 2009 01:19 PM
Steering Wheel mlw911 Defender Technical Discussions 8 April 4th, 2006 09:54 AM
stock suspension sheki Defender Technical Discussions 4 September 29th, 2005 09:21 PM
