Suspected blown motor mount 300tdi - Defender Source
Old August 1st, 2010, 12:56 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Have a new vibration on the rover, I'm thinking motor mount (I guess technically possible its a trans mount too) due the the excessive vibes really being bad while on the go pedal and me recently greasing all the propshaft ujoints.
Thoughts?
Posted from my BlackBerry using BerryBlab
------ Follow up post added August 1st, 2010 12:59 AM ------
Sorry about the double post
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old August 1st, 2010, 05:54 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
The engine mounts don't usually give lots of vibrations through the vehicle, unless the rubber piece has totally dissapeared and it's "metal on metal"
What does give vibes though, are the UJs when they're on their way out.... eventhough you've just greased them, if there is a duff bearing in one of them, then that'll cause issues.
Also, check the sliding joints, but i'd go for the UJ's myself.
Old August 1st, 2010, 08:59 AM
I vote for UJ too...
Old August 1st, 2010, 11:29 AM
Danny, chock the wheels and put the transmission and transfer case in neutral and release the hand brake. Get under the truck with a pair of gloves on and push/pull on the driveshafts, making sure they rotate freely (any binding will make them feel tight when they are not). If your u-joints are going bad you'll feel play. It should be pretty obvious if you are feeling it under acceleration.
300tdi, motor, mount, tdi
NAS D90 300tdi exhaust? Chris Cox Defender Technical Discussions 19 June 13th, 2006 04:59 PM
300Tdi wings/ radiator finisher (defender) Lyman Wanted 2 March 8th, 2006 05:51 AM
1995 Discovery 300TDI, Trail Ready.... Joe B For Sale - Vehicles 1 June 23rd, 2004 06:26 PM
