Surrey bar bolts - Defender Source
Old June 2nd, 2015, 10:13 AM
dcraychee
Devon Craychee
1994/Defender 90
Surrey bar bolts
Can someone let me know the size bolts needed to install the bar on top of the front window to hold in my surrey top. I've been told 10mm but want to confirm.
Old June 2nd, 2015, 10:28 AM
there are a few bars involved. 2 with snaps that go above the front doors (called the snap rails) and by front window I'm assuming you mean windshield? That's called the Header Bar.
Old June 2nd, 2015, 10:43 AM
dcraychee
Devon Craychee
1994/Defender 90
Yes the header bar, do you know the size of bolts that hold that in place to the front windshield
Old June 2nd, 2015, 01:36 PM
DefenderMd's Avatar
DefenderMd
Ben
87 defender 110 3 door
Any that fit. Mine are 7/16 and 10mm HEXES. But w/e. if it fits through the hole... its the right one.
Old June 2nd, 2015, 01:41 PM
dcraychee
Devon Craychee
1994/Defender 90
Sounds good and thanks!!!
Old June 2nd, 2015, 02:01 PM
Make sure whatever you get, that it won't rust.
Old June 2nd, 2015, 03:06 PM
Dogpilot's Avatar
Dogpilot
James Wallace
Defender 90 1997 NAS ST
On mine at least, a '97 I used M6 (10mm heads) x 1.5 the pitch is 1.0. I would recommend stainless as well and I would spray them lightly with oil before you insert them. They will get a tendency to bind a bit with the rivnuts at the top of the windscreen, since they are aluminum. If you have the tool, you may want to tighten the rivnuts a bit or one or two may spin when you go to remove them down the line. I would also recommend a washer under the bolt head, since the bolts will tend to score the soft aluminum mounting bar.
Old June 2nd, 2015, 11:42 PM
dcraychee
Devon Craychee
1994/Defender 90
Thanks Digpilot!! I appreciate all the advice , I will keep you posted.
Old June 2nd, 2015, 11:49 PM
nflory's Avatar
nflory
Nate
1997/Defender 90 ST
I have seen your d90. You may want to burn it instead.
Old June 3rd, 2015, 12:06 AM
bjf's Avatar
bjf
barry f
94 ST #395
I don't get it.
Lots of guys in the southbay with trucks. Let's make sure to never have a meet up.
Old June 3rd, 2015, 12:09 AM
nflory's Avatar
nflory
Nate
1997/Defender 90 ST
Let's have a meetup at the cheese cake factory.
Old June 3rd, 2015, 12:19 AM
nflory's Avatar
nflory
Nate
1997/Defender 90 ST
Bjf. Let me know about the meet up. Cheesecake Factory has excellent food at a reasonable price.
------ Follow up post added June 2nd, 2015 11:23 PM ------
I just realized this is Barry! Let's grab some Cheesecake!
Old June 3rd, 2015, 12:27 AM
bjf's Avatar
bjf
barry f
94 ST #395
Still didn't answer about why he should burn the truck.
Have we met?
Old June 3rd, 2015, 01:27 AM
nflory's Avatar
nflory
Nate
1997/Defender 90 ST
I don't think so. Do you go to the cheese cake factory in redondo?
Have we met?
Old June 3rd, 2015, 07:43 AM
Are you drunk?!
Old June 3rd, 2015, 08:36 AM
tim
Timothy Homewood
Defender 50th going topless
Yes, m6 is correct for the header bar..
Old June 3rd, 2015, 11:41 AM
dcraychee
Devon Craychee
1994/Defender 90
Thanks Tim.
M6 is it. Do you know if this is a bolt I can get at a local hardware store or do I need to special order?
Looks like I can go and ask the guys at Chessecake Factory, since it's close to my house! HA!
Old June 3rd, 2015, 11:50 AM
Upload a pic of your truck btw! Or create a Registry.
Old June 3rd, 2015, 11:56 AM
Dogpilot's Avatar
Dogpilot
James Wallace
Go to the wall of drawers at an Ace or True Value Hardware store, they should have them in a variety of lengths and in stainless. It would be in the wall of many drawers.
Old June 3rd, 2015, 12:01 PM
nflory's Avatar
nflory
Nate
1997/Defender 90 ST
Dcraychee and I will send some pics of our trucks from the factory this weekend.
bolts
Badger Surrey vs. RN Surrey ///Maximus Defender Technical Discussions 4 January 25th, 2014 10:56 AM
4 Brush Bar Bolts Campbell Wanted 0 May 6th, 2009 10:56 AM
Brush Bar Bolts Campbell Defender Technical Discussions 7 May 2nd, 2009 01:30 PM
Surrey top swap inside vs over door roll bar versions paulb Wanted 3 April 26th, 2007 09:42 AM
Header bar, yellow hinges, tailgate bar clips mspell Wanted 1 October 4th, 2004 04:20 PM
