Superwinch X-10 went "pop"...repair options - Defender Source
Old July 8th, 2010, 08:22 AM
PMKColorado's Avatar
PMKColorado
Paul Koentges
'95 White D-90, #2625
Pulling out a sign post with snatch block line doubled when it failed. Surprised that it did not have an overload...worked nicely at Wheeler Lake last weekend (helped a jeep & a Montero trying to make 3rd obstacle)
-learned the limit, however, my D-90 was on level ground, no scotch blocks, idling and did not slide.
-clutch/handle will not engage,
-does run
-where to start?
-replacement parts source
Thanks as I have never serviced a winch before...
Paul
Old July 8th, 2010, 03:27 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Step one is to take it apart and figure out how all the broken bits fit back together properly. Until you know what is damaged you won't know what replacement items you need to order.
Old July 8th, 2010, 04:12 PM
Yup, and then you can call superwinch directly for parts, but I am sure there are lots of other distributors.
Old July 8th, 2010, 07:12 PM
PMKColorado
Paul Koentges
that will be the plan...
Old July 8th, 2010, 09:18 PM
Winch repair is easy. Comes apart quickly and usually painfully obvious what is wrong.
Old July 8th, 2010, 09:44 PM
Chris Velardi's Avatar
Chris Velardi
Chris Velardi
1975 101FC
Check the winch solenoids
Chris "V"
Old July 8th, 2010, 09:47 PM
They would not cause the clutch lever not to engage.
Old July 8th, 2010, 10:03 PM
Chris Velardi
Chris Velardi
1975 101FC
The lever on my old E 12,000 and my old superwinch 9000 used to jam all the time . you would have to occasionally try and power in and power out a touch to realign the gears to move the handle. The only thing I ever fried on them was the solenoids
Chris "V"
Old July 8th, 2010, 10:35 PM
I guess it is worth a shot. You can test the winch by running wires direct to the motor to see if it spins.
Old July 15th, 2010, 10:23 AM
PMKColorado
Paul Koentges
repaired...
X10 is mounted into a SG bumper; apparently, I had put enough torque on the winch that it distorted enough to pop the clutch lever pin out of the gear end...no damage. While it was apart, I serviced, greased, etc and remounted making sure all studs were properly seated. I noticed one stud to bumper was stripped and required a heli-coil. Realy easy to service but a pain in the ass to R & R as I had to take my bumper off...heavy for 2 people.
winch
Superwinch Husky 10 roller fairlead JSQ Wanted 20 April 30th, 2013 11:46 PM
Ball joint repair kit and Superwinch solenoids Davin For Sale - Parts 4 February 25th, 2009 01:57 PM
Superwinch Epi9.0 gtg067i Defender Technical Discussions 6 September 15th, 2005 09:33 AM
Roll cage options mod4b Misc. Chit-Chat 2 March 23rd, 2005 01:17 PM
exhaust- options Nigel Defender Technical Discussions 11 October 20th, 2004 10:34 PM
