Super swamper tsl radial 36x12.50x16 - Defender Source
Old June 18th, 2014, 11:59 PM
UtahD90
Adam Harward
1995 Defender 90 SW
Found a deal on a couple of these tires new. Wondering if anyone is running these? I've got ome 2" lift springs.
I know I'll need longer bump stops....any recommendations?
Also tire spacer recommendation would be appreciated.
Old June 19th, 2014, 07:09 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
I'm running bia ply 36 inch TSLs and have been very happy with them. Same size but on a 15 inch rim
Old June 19th, 2014, 08:33 AM
UtahD90
Adam Harward
1995 Defender 90 SW
Any pics you might be willing to share? Did you end up putting longer bump stops on?
Old June 19th, 2014, 09:39 AM
You must use longer bump stops and trim or change to different flares. Obviously wider rims with less offset are required as well.
Old June 19th, 2014, 09:49 AM
slorocco
Dan Prasada-Rao
I was just referring to the tires, mine are mounted under my 109 in this pic from 2010. Mine is the 109. That 88 is running even larger rubber, 39.5 inch Iroks
Super Swamper TSL Radial 265/80/16 The Dro For Sale - Parts 4 November 16th, 2010 08:02 AM
Super Swaper Radial/tsl 265/80 r 16 sflash868 For Sale - Parts 0 January 28th, 2007 08:20 PM
SSR Super Swamper Radial/TSL tires 35x10.50-16 lrnasd90 For Sale - Parts 8 November 4th, 2006 10:25 PM
35/16/15 Super Swamper TSL Boggers & rims TDI Guy For Sale - Parts 4 October 18th, 2004 10:18 AM
36x12.50R15 TSL/SX questions DBZ2009 Defender Technical Discussions 11 October 28th, 2003 07:58 PM
