Sunroof leak - Defender Source
Old June 29th, 2011, 03:20 AM
Rochebm
Brandon Roche
97' SW #485
Sunroof leak
Any suggestions on how to fix a leaking sunroof? I did a search and didn't come up with much. Its leaking at the front, from the 2 clips. Thanks
Old June 29th, 2011, 07:14 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Usually have to remove them and reinstall with a new gasket (or some sealant....not silicone). Good luck.
Matt Browne
Old June 29th, 2011, 09:23 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
I FINALLY got mine to stop leaking. by using some sticky weatherseal around the edge (on the outside) combo'ed with some vaseline around the actual gasket, then cranking down the knob. The vaseline sweats a tiny bit, but thats better than the seat always being wet...
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old June 29th, 2011, 10:19 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I've had the same problem if the truck is parked on uneven ground and there's been lots of rain. I cleaned the seals and rubbed in a lite oil with my finger. It's been about a year and no issues yet. I also try very hard not to park in direct sunlight.
Old June 29th, 2011, 03:58 PM
Chaucer
Will
93 110 | 97 90
Yeah a really good cleaning to get all the debris and dirt/dust out of the seals. I never lubed mine up, but that makes good sense.
The above really works if the leak is from debris creating a tiny break in the seal allowing water to seep through. If that doesn't do it, you may need to remove your headliner(s) and seal up where the sunroof frame meets the roof.
Old June 29th, 2011, 04:56 PM
mightymo's Avatar
mightymo
matthew m
'95 Disco 300TDI
SO glad this thread was posted... I too am suffering from "WETSEATITIS." From what I gather replacing the sunroof is a bit of a pain in the arse?
Old February 7th, 2013, 01:27 PM
rcfarris's Avatar
rcfarris
Rory Farris
multiple
looking for replacement rubber seals for my sunroof. checked with shp and rn with no luck. any ideas?
Old February 7th, 2013, 01:49 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Part numbers:
Glass to frame seal RTC5942 - Available (SO for $122)
Frame to roof seal MWC9500 - NA? Newer part number perhaps?
Old February 7th, 2013, 03:48 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
maybe RDS? Call George. You know there is nothing really to it. If you bought some foam gasket (weather strip) from lowes it would be better. Its really sad but true.
roof, sunroof
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
Oil Pan Leak Eric Siepmann Defender Technical Discussions 11 May 25th, 2005 09:47 AM
Sunroof Seal on a 95 SW... norros Defender Technical Discussions 3 January 3rd, 2005 06:01 PM
Vacuum Leak Eric Siepmann Defender Technical Discussions 2 November 25th, 2004 09:11 PM
Exhaust leak dmarchand Defender Technical Discussions 12 February 4th, 2004 03:12 PM
