Sunroof and Other Leaks - Defender Source
Old February 17th, 2012, 05:02 PM
hunterjah's Avatar
hunterjah
Jesse Hardin
Past: '97 D90 LE #135
Has anyone run into issues of leaks around the sunroof on your SW? I have a chunk out of the sunroof gasket (looks like the previous owner used caulk to fix) and am hoping I can find a new gasket to replace it. But, whenever it rains, I get water coming in from the roof and it ends up running down the front sides of the windshield and at the gasket where the door meets the door frame above the window. Any thoughts on where/how to trouble shoot?
I am pretty confident the water is coming through the sunroof gasket for the first leak, however, I think I'm also getting water in the drivers side vent cover which is coming out where the cardboard is underneath the dash. Any thoughts on that leak?
Current Stable:
2016 BMW M3 (Mineral Grey)
2013 Ford Raptor (Tuxedo Black)
Previous Rovers:
1997 LR D90 LE - #135
1997 LR D90 ST - #1185 (BRG)
2000 LR Discovery SII (Oxford Blue)
2008 LR LR3 HSE (Alaska White)
2012 LR LR4 Lux (Fuji White)
Old February 17th, 2012, 05:06 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
Gasket/front vent cover is usual suspect if you have water dripping from bulkhead area.
If you take off the plastic trim on the sides of the windscreen frame you can see if it's dripping from the roof and then down..........unlikely.
Sunroof will drip straight down.......hate sunroof.......won't ever get one again in a Defender......ever!
Old February 17th, 2012, 10:43 PM
Skeena river rover's Avatar
Skeena river rover
jeroen
1997 300 TDI 110
If it does not leak i would start to worry It is a common fact that they leak. Mine is still leaking and a need to fix it to. I have to re-kit the seals/ gaps/ cracks in my roof. Also the gutters on the side need new kit.
Old February 17th, 2012, 11:06 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I replaced my bulkhead vent seals with the series III seals from rovers down south and that appears to have stopped the puddles on the floorboards.
Old February 18th, 2012, 08:39 AM
kinetic's Avatar
kinetic
Kinetic Adventures
TDI's
What do yo mean by re-kit? My gutters look like an ant with a samurai sword went to town on them.
Thanks!
Old February 18th, 2012, 10:23 AM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Is there an "easy" way to get the vents off to replace the gasket? It's quite the tedious task to get to the nuts on the bracket.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old February 18th, 2012, 11:22 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I have no idea if there is an easier way. I took the cotter pins out of the hinges and then just moved the vents around until I could get a couple of wrenches on either side of the bolt that attaches it to the lever. There are a couple of washers that want to fall into the abyss when you loosen that little bolt. Getting it all back together took a few attempts.
Old February 19th, 2012, 12:04 AM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
I've started the work on mine, but it's a time consuming process, so it's taking a while.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old February 20th, 2012, 11:44 PM
Skeena river rover
jeroen
1997 300 TDI 110
For Aaron,
What i meant is this: Makes a big difference.
ID:	47949   Click image for larger version
Old February 21st, 2012, 08:21 AM
kinetic's Avatar
kinetic
Kinetic Adventures
TDI's
Thanks for the pics, that's what I was hoping you were talking about... working on the same thing as we speak to try and beat the summer rains down here.
-Aaron
roof, sunroof
