Sun Visor Disassembly - Defender Source
Old August 6th, 2011, 09:22 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I have a dark grey headliner in my 90 so I thought I could just buy the ST sun visors (which are dark grey) and fit them. No suck luck. The sun visors are identical but the hinges are different and the mounting holes are in the wrong place.
Has anyone disassembled the hinges off of a sun visor before? Is this possible?
Old August 7th, 2011, 10:11 AM
I have not dissambled the visor. don't even know if it's possible. I did however use rivnuts in the roof frame to mount both visors farther outboard, since I installed a larger aftermarket auto-dim mirror. easy job once the headliner is down. The visor arms as I'm sure you know can adjust in width by sliding in and out quite a bit.
Old August 7th, 2011, 12:58 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Good news. They come out and to my surprise nothing broke in the process. I have to swap one side of each visor as the mount is totally different (180 degree bend versus 90 degree bend).
Old August 7th, 2011, 05:34 PM
Thanks for sharing Carl. One of mine is frozen in place (I assume rusted) but wasn't sure of the construction. It looks like a little pb blaster while sitting in a vertical orientation should do the trick to fix it!
Originally Posted by pendy
I'm here for the D's
Old August 7th, 2011, 10:44 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
No problem. The new pins are actually lubed with some white goop. Just pull in the direction of the pin and wiggle back and forth. It's a snug fit but will come right out.
Old August 9th, 2011, 06:22 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Carl - Did you pick up a new or used set of ST sun visors? Where from? I'm wanting to change to a darker color for the new headliner to mitigate paw prints and need the sun visors to match somewhat.
Old August 9th, 2011, 07:32 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I was looking for used but nothing came up so I ordered new from LRSeries.com.
Old August 10th, 2011, 03:43 AM
Sunvisors are for short people.
Old August 10th, 2011, 06:30 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Objection! I feel that is a direct slight against me.
Semper Fi!
Old August 10th, 2011, 07:28 AM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
So that explains my infatuation with sun visors.
------ Follow up post added August 10th, 2011 07:28 AM ------
Thanks!
Old August 10th, 2011, 08:02 AM
Now that you mention it, I have never actually used mine. I think they keep a bit of rain out though.
Old August 10th, 2011, 09:55 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
I just use them to direct the flow of heat during the winter.
assembly
Soft Top Sun Visors wanted Manimal Wanted 2 July 16th, 2011 03:35 PM
Sun Visors? Where can I source some black ones? D90Overkill Wanted 3 June 20th, 2008 06:14 PM
Sun Visor Pics TDI Guy Defender Technical Discussions 4 March 22nd, 2006 12:22 PM
Sun visor for a D-90 DaveG Wanted 0 November 13th, 2005 05:49 PM
Sun Rims for sale (mtn bike) rover4x4 For Sale - Parts 0 September 15th, 2004 01:04 PM
