Suggestions for carpet "glue" - Defender Source
Old July 31st, 2011, 11:44 AM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
I am debating on installing the carpeting in my (For Sale) 110 but the idea of smearing all these pristine freshly painted interior surfaces with nasty glue breaks my heart. I am sure many of us have faced what I did when i got this truck, where some "well meaning" previous owner had used not only ugly non-stock carpeting but some unbelievably permanent glue that you literally have to grind off. I mean, I have had an easier time grinding down metal bolt heads than grinding off the damn carpeting glue. Any suggestions/experience as to what I could use that would not only work but also not leave the next owner with a nightmare if they ever want to remove the carpet?
George
Old July 31st, 2011, 12:26 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
When I replaced the factory carpet in my 97 ST, all that held it in place was 2 sided tape. When I reinstalled, I used a combination of 2 sided tape and 3M spray adhesive that I pickup up at Home Depot.
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old July 31st, 2011, 03:39 PM
I know of no OEM car that glues its carpet to the chassis. Nor 2 way tape for that matter. Most if not all nowadays is stitched or molded and occasionally (in Mercedes) foam-backed for acoustic dampening.
Sounds like a sure way to lower your resale value.
Old July 31st, 2011, 03:44 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
If you have to glue it, use something like 3M Super 77 that holds well, but doesn't make the crazy unremovable mess. Super 77 can be removed with 3M Adhesive remover or any citrus based cleaner.
Old July 31st, 2011, 04:17 PM
Reese_D90's Avatar
Reese_D90
Reese
I meant my SW not ST
1997 D90 ST #1953
2006 Range Rover
1995 D90 ST (sold)
Old July 31st, 2011, 08:45 PM
Rocketman's Avatar
Rocketman
Scott Y
95 D90 SW, 2003 Disco II, 93 D110
I used standard two side carpet tape to install my carpets in my 93 110. The local Lowes has two variants, one for indoors and one for indoors/outdoors. I used the latter. Worked fine!
Old August 8th, 2011, 11:51 PM
OahuDefender
Jason
1994 D-90
Sorry for asking the obvious question, why are you putting in carpet at all??? It just makes it that much harder to vacuum out sand and dirt, which should be lining the inside of your Defender on a regular basis. I think rubber mats all around are the way to go, but that's just my opinion.
Old August 9th, 2011, 07:00 AM
Francois's Avatar
Francois
Francois
1986 110
X3 on the 2 sided tape. Can be easily removed if you need to replace the carpet. I used it for the load area of my 110. I did not use any tape for the middle seat and driver/passenger areas, so that I can take out the carpet sections when they get wet.
Francois
Looking for Front Seat Suggestions smenzel Defender Technical Discussions 39 February 26th, 2006 07:55 PM
Suggestions for shipping A chassis from ME to NJ TDI Guy Misc. Chit-Chat 9 January 22nd, 2006 08:28 AM
no spark suggestions? mattdh Defender Technical Discussions 12 April 25th, 2005 09:59 PM
Just failed an emissions test, suggestions? Hans Defender Technical Discussions 6 October 11th, 2004 12:12 AM
Suspension Suggestions ? rcmorgan540 Misc. Chit-Chat 9 June 19th, 2004 12:00 AM
