Suggestions for brake replacement kits - Defender Source
Old May 12th, 2013, 06:43 PM
Zooraya's Avatar
Zooraya
Bani
1995 NAS D90
I need to replace the front and rear brakes on my D90. I've searched the forums for advice on what parts to buy but haven't really found the advice I'm looking for.
Like most people, I value a truck's ability to stop as much as it's ability to go. I've also experienced the crappy performance of using inexpensive rotors and pads on other vehicles. My problem is, I don't yet know what to get as this is my first time replacing the brakes on this truck.
Should I go with vented, drilled, slotted, dimpled? For the front? For the rear? Is there a brand that you guys vouch for?
I've seen full replacement kits on roverparts.com. The lower end is around $380 for rotors, pads, and new hardware. The higher end kit contains EBC brakes and is about $200 more. Both of these kits give me sticker shock considering I'd change all four corners on my XJ for $250 using the good stuff.
I don't like to cut corners but also don't want to buy something that isn't worth getting. I need to order a kit that can arrive by this upcoming Saturday. Any suggestions?
Thanks in advance for your help.
Old May 13th, 2013, 12:44 AM
Zooraya's Avatar
Zooraya
Bani
1995 NAS D90
At first glance this kit seems pretty darn pricey.
http://www.roverparts.com/Parts/9995EBC.cfm
Then again there's the compromise of genuine pads with generic rotors
http://www.roverparts.com/Parts/9995GA.cfm
Ultimate goal is getting the best stopping power possible to help with towing.
Old May 13th, 2013, 02:05 AM
Zooraya's Avatar
Zooraya
Bani
1995 NAS D90
After digging some more I found another thread that was helpful.
http://www.defendersource.com/forum/...ghlight=ferodo
I think I'll go with the second of my two choices above.
Old May 13th, 2013, 03:28 AM
ssbartley1's Avatar
ssbartley1
Steve Bartley
1997 SW #160
Brakes
The non genuine pads squeaked and squealed so bad I replaced them with LR
Steve B-
Otterberg, Germany
"Walk tall, kick ass, learn to speak Arabic, love music and never forget you come from a long line of truth seekers, lovers and warriors."
- Hunter S. Thompson
Old May 13th, 2013, 03:37 AM
Zooraya's Avatar
Zooraya
Bani
1995 NAS D90
Thanks for the tip Steve. I'm ordering the kit below. It has aftermarket rotors but LR genuine pads. Seems to be a good combo.
Old May 13th, 2013, 10:00 AM
ssbartley1's Avatar
ssbartley1
Steve Bartley
1997 SW #160
Looks like the better way to go!
Steve B-
Otterberg, Germany
Old May 13th, 2013, 10:38 AM
I use "OEM" pads and whatever rotors will tillery sends. Im hard on brakes and these have served me well. Ive used brembo rotors on my RRC with mintex pads, it stops well no sqeaks but lots of brake dust.
Old May 15th, 2013, 07:34 AM
blenkush's Avatar
blenkush
Severin Blenkush
97 D90 LE, 10 Lotus Exige S, 05 LR3
I tried EBC drilled/slotted rotors and the Greenstuff pads. I am pleased with the rotors but did NOT like the pads. They took forever to heat up and start working - great for driving twisty mountain roads in a sports car, not so great for the D-90 (especially on cold mornings, yikes!). I swapped just the pads out for Ferodo and am much happier.
Old May 15th, 2013, 08:07 AM
Same here. Non genuine rotors seem fine, just changing the pads solved it for me (on two different trucks)
Originally Posted by pendy
I'm here for the D's
Old May 15th, 2013, 08:46 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I have used aftermarket pads on my RRC, D90 and DII---usually gotten at the last minute from either Oreily or Napa. I use a generous portion of the red brake antisqueel rubber backing stuff (CRC Disc Brake Quiet is what I use) on the back of the pads and I just don't get brake squeel. I hope I am not jinxing myself, but I have had these trucks for the last 13 years ish...
brake
Stainless exhaust replacement suggestions? stnmikita Defender Technical Discussions 10 December 23rd, 2011 02:30 PM
fuse box replacement suggestions Gkase Defender Technical Discussions 2 March 28th, 2010 02:10 PM
Looking for Front Seat Suggestions smenzel Defender Technical Discussions 39 February 26th, 2006 07:55 PM
Stainless Fastener Kits Remaining JimC For Sale - Parts 26 November 10th, 2005 12:26 PM
Front Vent Seal Replacement Campbell Defender Technical Discussions 16 October 28th, 2004 09:11 PM
