Suggestion? - Defender Source
Old August 27th, 2010, 02:48 PM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
Cool Suggestion?
Looking to put a 2" receiver on my front bumper, mostly to be used for a bike rack. Any of you guys have any suggestions? Will the stock front bumper hold-up to the weight? Is there a bumper I should look into? Any help would be great. THANKS...
Weldon
Old August 27th, 2010, 04:07 PM
bharris's Avatar
bharris
Brad Harris
1994 d90 300tdi "Nola"
Originally Posted by Weldon View Post
... mostly...
much of the answer to your question is within this word and what you mean by it...
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
what about something similar to what I put on my rear crossmember (for the same purpose)
http://www.rigidhitch.com/default.as...emcode=2201172 - with a backing plate of some kind.
Or you could use what I did for my TJ -> http://www.amazon.com/Putnam-Hitch-3.../dp/B000AKHWYM
I had a friend make an S-shaped piece of steel to tie it into the nearby bodymount under the grill, but bracing it somehow shouldn't be too hard. U-bolts and some scrap steel maybe?
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old August 30th, 2010, 03:18 PM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
There's got to be a much less expensive means than this?
http://roversnorth.com/store/p-5235-...-defender.aspx
There's got to be idea's?
And yes most of the time used for bike rack.
Weldon
Old August 30th, 2010, 03:46 PM
D90DRC
D Cantrell
1997 D90SW
You get what you pay for... Cheaper make one yourself but consider, by the time you get the materials weld it up and paint it or coat it your not saving that much...
Still waiting for the Hope and Change to start
Old August 30th, 2010, 03:48 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
I would stay with the Rovers North Product. What you need to think about when it comes to stress is that for every inch of steel your bikes are away from that hitch the amount of stress increases.
For example: If you put an item in a hitch 20 inches away for every pound that item weighs the pressure on the hitch will be 20:1. So if you have 40 lbs of bikes and the CG (center of gravity) is 20 inches away, your stresses could exceed 800 lbs, and that does not include hitting a pot hole at 40MPH.
shock suggestion bennett Defender Technical Discussions 8 June 7th, 2010 03:14 PM
New to me Defender - need suggestion on shop manual WI-ROTTIE Defender Technical Discussions 7 May 31st, 2007 08:54 AM
roof rack parts misfit Wanted 10 October 26th, 2006 11:13 AM
quick help on Miller Econotig suggestion Davis Defender Technical Discussions 4 May 18th, 2006 09:52 AM
4.6 or? Rick Carlisle Defender Technical Discussions 29 May 27th, 2004 09:52 AM
