Suggested PSI for driving on sand? - Defender Source
Old May 28th, 2011, 04:49 PM
ditskovich's Avatar
ditskovich
dmitry
Range Rover Sport 2013
what would you lower PSI to for driving on sand?
Old May 28th, 2011, 05:58 PM
TS888's Avatar
TS888
Tony Sims
1984 110
Tire size? What type of wheels? Tube or tubeless?
Tony
1984 110 "Smokey" (sold)
Old May 28th, 2011, 06:07 PM
The lower the better. Start at 15 psi and lower when needed. The lower you go the more careful you need to be when cornering and keeping the speed down. Carry an air compressor to reinflate.
Old May 29th, 2011, 05:47 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Low does it. Lengthens the foot print. Make a huge difference.
Mike Hammond
Old May 30th, 2011, 07:41 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
On Sand you want to float on top of the sand as compared to cutting through it. If you notice on the sand buggies they have a "high Floatation" tire that is really wide with a flat footprint. As the others have said by lowering your air pressure you will increase the size of your tires contact area. Decreasing the pressure to the low teens shouldn't be a problem no matter what your tire/wheel set up you have. If you go into the single digits you may risk getting a flat, bead popping off the rim or sand getting into the bead area. Usually it is easier to follow the ruts created by others as long as they are not too deep for your rig.
Land Rover 110
Old May 31st, 2011, 10:04 AM
Rocketman's Avatar
Rocketman
Scott Y
95 D90 SW, 2003 Disco II, 93 D110
I have always dropped my tire pressure down to 12-15 psi for soft sand. I have done plenty of soft sand driving on Nantucket with my 95 SW (since new) and have never had a problem or gotten stuck. One time on some really soft sand, the axles were touching the sand and the 90 easily drove out of it in locked center/low range. Do yourself a favor and get a couple of the tire deflators that you can screw on to the valve stem and they deflate down to about 15 psi, or else you will stand by each tire forever pushing the valve in to deflate them
Old May 31st, 2011, 02:35 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
For tires ~10-11" wide, I always used 12psi for soft sand.
If wider than 12" you can usually go up to ~15psi.
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
vin
Caliper rebuilding, suggested or to be avoided? Hans Defender Technical Discussions 10 September 3rd, 2005 07:10 PM
D90 Sand Surfing DiscoDino Defender Technical Discussions 0 August 7th, 2005 05:14 PM
Sand ladders Rover- Girl Defender Technical Discussions 9 June 28th, 2005 12:39 AM
Fuel Pump running PSI and deadhead PSI? RedRhinoProducts Defender Technical Discussions 0 February 27th, 2005 02:35 PM
Sand Ladder mounts? wicks Misc. Chit-Chat 4 July 29th, 2004 04:16 AM
