Suggest a snatch block and wiring question for winches - Defender Source
Old July 18th, 2016, 08:43 AM
Naplm00
M
Got a smittybilt 12k with syn line from Amazon super cheap. Need some insight.
Want a snatchblock that isn't $100 but will work well with syn rope and the weight. Hf has a 20k for $27 but I am definitely skeptical.
For wiring I plan to use 2/0 gauge welding cable to a forklift connector,possibly run through split loom or heater hose. Plan was to go along the rh frame rail when facing the truck, any issues here?
Also anyone in the nj/ny area have a hydraulic crimper I could rent?
Old July 18th, 2016, 09:06 AM
speedpin's Avatar
speedpin
Looking ;)
I ran the wires down the LH rail (engine side) into the battery box.
Air gas has the wire (welder) and terminals needed. They will also crimp them on at no charge.
~ Semper Fidelis ~
Old July 18th, 2016, 11:07 AM
Ray_G's Avatar
Ray_G
Ray Gerber
From what I've seen any snatch block will work fine, I typically do ARB or TJM but that's just been b/c of availability and have never bought a synthetic specific block. If I were using it every day, on every trip, I might consider it once I started breaking lines but none of that applies. I think the $60 run of the mill name brand is more than sufficient-concur on not being sure about HF.
r-
Ray
Old July 18th, 2016, 11:33 AM
Naplm00
M
Werd good info here
winch, wiring
Warn Snatch Block. NIB down_shift For Sale - Parts 9 December 9th, 2012 06:24 PM
The Great Overland Journal WARN Snatch Block Promotion Wolf Fabrication Misc. Chit-Chat 0 August 10th, 2012 07:09 AM
F/S Warn Snatch Block and D-Ring Male and Stap Buddie For Sale - Parts 3 February 7th, 2012 11:58 PM
What would you suggest? Differential Paint? JBinAlabama Series Technical Discussions 11 December 14th, 2011 08:34 AM
ARB's, Dixon-Bates, big snatch block maybe TT's. Roving Beetle Wanted 0 April 11th, 2010 09:47 PM
