sudden eng. temp rise - Defender Source
Old November 2nd, 2010, 10:20 AM
discotdi
Todd Miller
Land Rover
Ok, so I have a 200 tdi which normally runs at around 180F. I have a viscous fan but no fan shroud so it doesn't really do much. made it throught the hot summer like this with no problems. recently I have noticed when in traffic the temp has risen to around 200F, but as soon as I started moving and got air flow it would drop back to 180. today, on a cool day I noticed while sitting at a traffic light that the temp was rising and it climbed to above 200, up to 210 or so. when I started moving it went back down. I was not stopped long and I am worried that if I stop for longer it will continue to climb above 210.
what should I be looking for to cause this sudden rise in temp? also, what is an engine damagiing temp? at what temp should I shut her down if I see it rising?
I have not noticed any coolant loss etc, but will check it when it cools down. I am now at work and can't really go out a and f*** around with the car in the parking lot.
Old November 2nd, 2010, 10:27 AM
Mine does that when coolant is low. With a pressurized system and antifreeze you can hit 230 without damaging things but its scary. Get a shroud or electric fan.
Old November 2nd, 2010, 10:45 AM
if nothing else changed and it is getting hot now with the cooler weather, I would suspect the fan clutch.
Old November 2nd, 2010, 11:46 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
I agree. If the coolant is not low and the temp was fine in the summer, fan clutch is the next suspect.
Wont run at temp Neo Defender Technical Discussions 12 February 24th, 2006 06:54 PM
Thread size for temp sender mgrgpg Defender Technical Discussions 3 July 1st, 2004 12:00 PM
water temp stabilizer switch david jenson Defender Technical Discussions 1 June 16th, 2004 08:50 PM
ZF trans temp? dmarchand Defender Technical Discussions 2 May 17th, 2004 10:45 AM
Possible sudden rise in membership chrisvonc Misc. Chit-Chat 14 March 12th, 2004 09:25 AM
