Subwoofer Amplifier chassis ground - Defender Source
Old December 6th, 2011, 12:17 PM
rockstardave's Avatar
rockstardave
Dave Dulansey
1995 D-90
Question for those of you who have hooked up a powered subwoofer - where did you hook up the ground wire for the amp? I was able to fish all the wiring underneath the floormat on the side. I have the one piece mat that covers the entire bed and wheel wells.
Previous owner drilled a hole on the seat box cover (yes, I know) so I might as well use that to run the power cable.
As you'd imagine, I'd rather not drill any holes or remove any bolts that will cause a lot of cussin' and what not.
Old December 9th, 2011, 07:53 PM
rockstardave
Dave Dulansey
1995 D-90
OK I answered my own question - I hooked it up to the seatbelt mount on the wheel well. Tucked it under the rubber mat and it works great. Now my truck has bass!!!
Old December 9th, 2011, 08:43 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
for my amps, I grounded them to the rollcage bolts near the inertia belt. Then from there it goes to the chassis just in case. I made sure to ground rollcage and chassis together, since the rollcage bolts are in close proximity to the amps.
Robert Deniro
Old December 9th, 2011, 08:51 PM
Rosproline157's Avatar
Rosproline157
Matt Oaks
1992 Defender 90
Buy an $2 volt meter from advanced auto. That will fix a lot of your questions.
300Tdi intermittent start issue - starter or main chassis ground? nathanwind Defender Technical Discussions 30 February 21st, 2015 10:04 PM
NAS D-90 Land Rover Cassette/radio and amplifier eric_besore For Sale - Parts 4 May 4th, 2005 03:22 PM
Should I sell my chassis? JimC For Sale - Parts 14 May 11th, 2004 02:59 PM
Rover Build - Rolling Chassis ?s Jase Misc. Chit-Chat 14 March 4th, 2004 10:32 AM
Replacing ground wire questions vesparover Defender Technical Discussions 1 October 27th, 2003 04:01 PM
