Substitution parts: oil filters - Defender Source
Old July 2nd, 2007, 09:52 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Hi,
I went to the local parts store yesterday to buy a new oil filter. I'll use that opportunity to update the substitution parts list (http://www.defendersource.com/tech/part_sub.html).
Here what seems to be compatible with the 3.9L V8 engine on the Defender (I think same applies to the 1997, but I don't know for sure):
- Fram HP16
- Fram Tough Guard TG16
Slightly longer than stock (longer is better AFAIK for oil filters and they clear the steering rods):
- Fram HP45
- Pro Tec 104
Can someone confirm that they are not other references that would work better? (I left out the K&N, Mobil and someotherbrand filters because I did not write them down)
MonLand
1995 D90 NAS
1996 Discovery NAS
Old July 2nd, 2007, 11:40 AM
PH8A fram (99% sure that is the number, but I don't use fram so I cannot be 100% sure) and equivilents. I used the ford motorcraft part when rover ran out of filters.
Old July 2nd, 2007, 05:05 PM
NAPA GOld 1068 or 1452
Old January 23rd, 2008, 07:43 PM
the 1452 doesnt have the checkvalve. So 1068
Old January 23rd, 2008, 11:36 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Avoid the Tough-Guard TG series Fram filters like the plague, this is from personal experience.
Tried one once, and after I did that oil change I immediately had a significant drop in oil pressure at the gauge. Didn't realize what it was at first causing it, but I knew it started when I did the oil change. Same oil at the same viscosity that I had been using in the past, so it had to be the filter. Got a new one of a different type (HP16), and problem went away. This makes me wonder how much the oil pressure you get comes from the filter, and how much from the engine, but that's a different story.
I cut the failed filter apart to see what might have caused it, and found it to be the overpressure valve that the TG16 filter has. Supposed to maintain flow if the filter gets clogged, It's a spring loaded poppet valve at the bottom end, but it just sits against the frame of the pleated filter element. No kind of retention or sealing around it at all, just one piece of poorly stamped sheet metal sitting there. One small flex, and you lose the seal and the oil just goes around the actual filter material. crap crap crap design.
The HP16 is ok though, doesn't have that abomination in it, but still does have the checkvalve.
The checkvalves are easy to spot actually once you know what to look for. Look into the outer ring of holes in the filter. If you can see down into the filter and see the pleating of the element there is no checkvalve. If the holes are covered by rubber, it's there.
Oh, and the end nubbin on the K&N that claims you can use a wrench on it for changes? It sucks, you still need an oil filter wrench a good amount of the time.
-Hans
My oil line fix
My 100k stopped odometer fix
Old January 24th, 2008, 12:11 PM
61rover's Avatar
61rover
John Crouse
Oil Filter
I have also used the NAPA Gold 1068 and was pretty happy with it.
Old January 25th, 2008, 10:12 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I've found Wix to be the cheapest consistent quality filter.
http://www.discoweb.org/forums/showp...07&postcount=1
I'm pretty sure these also fit the 300Tdi.
I don't think the Wix 51773 will fit the V-8 Defender because of the steering damper, but haven't personally tried it on mine. Won't know about the 300Tdi until later this year.
I ran them for a while on my Discovery until I relocated the damper.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
part, parts
Oil Cooler Line Parts List Wolf Fabrication Defender Technical Discussions 30 November 7th, 2007 12:29 PM
Defender Oil Cooler Status Poll: Please Read. Hans Misc. Chit-Chat 4 March 12th, 2006 10:49 PM
Oil leak rustydefender Defender Technical Discussions 19 December 9th, 2004 09:06 PM
