Substantial Body Lean - Defender Source
Old September 13th, 2006, 05:34 PM
Joe P's Avatar
Joe P
Joe Pfeiffer
Black 97 D-90ST #0605
My truck seems to have developed a significant lean towards the drivers side. When I measure from the ground to the top of the wheel arch I come up with the following:
Drivers Front - 36.75"
Drivers Rear - 37.25"
Passenger Front - 37.75"
Passenger Rear - 38.75"
I ahd the shop switch the springs from the drivers side to the passenger side and the truck still leans.
I have Rovertym 2" springs and a SG 3-link, I also have the SG external front shock mounts and the stage 3 rear mounts. I'm putting on new shocks tomorrow to see if that is the culprit.
Any advice.
If the truck makes it - the trail wasn't tough enough.
If the truck doesn't make it - the truck wasn't tough enough.
Old September 13th, 2006, 05:39 PM
btate
Bryan Tate
d90
Have you gained alot of weight?
I've seen alot of cars on the highway that lean that way......
Couldn't resist!
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Check your tire pressure :D You might be developing a "dead spring". Make sure to jump up and down on the rig on all sides to settle everything and measure again, just in case if its a sticking shock like you said.
Old September 13th, 2006, 07:40 PM
redrover
Guest
Posts: n/a
I assume with the suspension upgrades you removed your rear swaybar? One winter I put the rear sway on to improve the pavement ride. I then had withdrawals and wheeled it with the sway on. On one side the sway bushing inverted and stayed that way until I released it with a crow bar. But the inversion caused the truck to sit exactly as you stated. If you switched Lf to Rt springs and still have a lean , it could be due to shocks if they are nitro charged. My lf rear leaks down to less than 100 psi monthly. Good luck JP
Old September 13th, 2006, 07:42 PM
Joe P's Avatar
Joe P
Joe Pfeiffer
Yes, sway bars are removed. Tire pressure is good to go. Hopefully the new shocks will help. Picking them up tomorrow from SG, I went with the 12" adjustable reservoirs.
Keep the ideas coming!
Old September 13th, 2006, 07:51 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
are your springs retained? If not, the spring may not be seated properly.
I had the same problem when I ran OME, when I switched to the Rovertym it went away. Another possibility could be, since the vehicles are hand made, that the spring seat isn't welded equally to the one on the other side. I don't think that would make up an inch, but it could contribute.
If all else fails, try new spring. Changing the shock isn't going to fix it.
Originally Posted by MuddyOval
Sheki, you are a wang too.
A wang is another word for, you guessed it, A DICK!
Nothing racist, just pure DICK!
Old September 13th, 2006, 08:06 PM
Joe P's Avatar
Joe P
Joe Pfeiffer
Springs are retained. The rovertyms are about 1-2 years old, but like I said I switched them from one side to the other and it still leaned to the drivers side both ways. I suppose I could buy new springs but should they be bad after only a year or two?
I'll check the perch mounts
Old September 13th, 2006, 09:07 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Hey Joe,
Maybe related, but maybe not too. Be sure to torque bown all the bolts on your 3 link as maintenance. Be sure that the two bolts attaching your radius arms at the frame end are equal too. Your springs should be fine after 2 years. 1 inch is way too much for shocks to be responsible for, even with no charge vs. 150. When did you first notice the lean?
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old September 13th, 2006, 11:14 PM
Joe P's Avatar
Joe P
Joe Pfeiffer
I've been checking the 3-link mounting bolts, but i'll check to make sure the radius arms are equal.
More thoughts? anyone?
Old September 14th, 2006, 12:53 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Have you aired it out at all lately? If you can't figure it out, next time you are out my way I can put some spring spacers in for you.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old September 14th, 2006, 08:41 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
I had a disco that did the same thing. turned out to be a bad shock.
Old September 14th, 2006, 02:18 PM
Joe P's Avatar
Joe P
Joe Pfeiffer
Put new shocks on.
Measurements:
Passenger Front 37.875"
Drivers Rear - 37.5"
Passenger Rear 37.875
More suggestions please.
Old September 14th, 2006, 02:46 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Take a close look at the spring perches. Any frame rust or rot?
Old September 14th, 2006, 02:49 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Joe-
did you notice a lean before? or not sure?
Try measuring the the length from the spring seat to the spring pertch. This may tell you if it is a mounting/frame issue or a spring/shock/bushing issue.
Also check the ground with a level to count that out. do you ahve anything heavy mounted int he truck?
When my extra fuel tank is full and water tank empty my truck leans.
Old September 14th, 2006, 03:02 PM
Joe P's Avatar
Joe P
Joe Pfeiffer
I just measured from the top to bottom of each perch and there is a 1/2" difference between the drivers side and the passenger side on both the front and rear. Wondering if a 1/2" spacer is all I need. Not sure of a 1/2" difference on the spring perch would result in a 1" difference in the wheel arched, but it seems like it could. I never really noticed before but maybe the more you lift the more you notice it.
Old September 14th, 2006, 03:55 PM
artm
Arthur Maravelis
97 SW
Really, the perches are different heights? That should explain why many suggest you buy handed springs - taller driver's side. Then why wouldn't we tack weld a spacer there and be done with it? No more handed spring nonsense.
My 97 has OME's and it sags to the driver's side - with less than 10K miles on them. Can't recall if they are handed (bought them from Rover Accessories).
Old September 14th, 2006, 04:53 PM
D90user's Avatar
D90user
steve
I bet that is it... Wierd...but not really these are rovers
I like the tack welding a spacer suggestion... although one of those pre made shim thingys that OME makes would probably do the trick... Now you have me curious on mine... but I think I woudl prefer not to know
Old September 14th, 2006, 10:07 PM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
My truck was leaning about 1.5" to the drivers side so I just had the springs replaced (2" rovertym). It still leans 1/4" to the drivers side. Whatever.
Old September 14th, 2006, 11:33 PM
artm
Arthur Maravelis
97 SW
Well, I'd say 1/4-inch difference is fine.
What springs did you have before and how old?
Old September 15th, 2006, 12:00 AM
oldscratchggf
nate
95 d90
I had Rovertym 3", but they were the old style. Probably 2002ish?
I ended up going with the RR1-2 and the RR4-2. I`m kind of pissed off though, because it is supposed to be their heavy duty spring but the rear end sags. I`m going to have to look into a way of dealing with this
body
lifting the body (not plastic surgery :-) cbass Defender Technical Discussions 11 April 25th, 2005 12:14 PM
Source for long body bolts? 1/2x7.5 inch grade 8 cgalpin Defender Technical Discussions 7 March 12th, 2005 12:59 AM
Looking for a wrecked D90 or D90 frame & body mdb77 Defender Technical Discussions 17 January 11th, 2005 09:54 PM
body work on aluminum mattdh Defender Technical Discussions 11 July 4th, 2004 02:47 PM
