SU Carbs Good? Bad? - Defender Source
Old April 24th, 2013, 11:47 PM
akrockhound's Avatar
akrockhound
Jack
1988 RHD 110
SU Carbs Good? Bad?
I have an '88 110 3.5 V-8. The truck and these carbs are new to me.
Any consensus on them? troublesome? reliable? serviceable? I see there is a shop in Kansas City that rebuilds them
Are there any tried and true conversions out there (like to a 4-barrel holley). Good place to go for manifold conversion parts etc? I remember on my series III there were some proven ways to take off the old zenith and put on a weber.
I have seen mention of folks redoing the top end of 3.5's to fuel injected - but for now I just am looking to learn about whether there are well accepted ways to go toward something more familiar to us folks in the US.
Thanks for your help in advance
Old April 24th, 2013, 11:50 PM
There is an edelbrock conversion available. I love 14CUX EFI, now having said that one of them will now let me down. Knock on wood.
Old April 25th, 2013, 12:03 AM
ArmyRover's Avatar
ArmyRover
Bill Ski
83 110 "Frankenstein"
The SU's are great carbs if you understand them and are good at carb set up. That being said, I love my Holley carb and edlebrock intake. You couldn't pay me enough to get me to take the time on the SU set up to get it running right.
I had SU's on MGB as well it now has a weber, huge improvement.
Unknown Author
716-898-8153
Old April 25th, 2013, 12:17 AM
BEIS's Avatar
BEIS
RYAN BEIS
D110 Soft Top with full rollcage
My 110 has a 3.5L V8 as well. Keep in mind, the Rover V8 is just a Buick 215.
Troublesome?: Sometimes. These engines are old, and our older engines HATE ethanol loaded gas. Therefore, fuel treatment (Sea Foam) is needed every once in a while. Fuel filters need replacing sometimes as well. They are simple to replace and can be done in 5 minutes.
Reliable?: Yes. These engines keep going and are very simple. Mine came to me with an Edelbrock Carb installed, with a single filter. I find that this is easier to maintain and clean carbon deposits with carb cleaner every once in a while. Most parts for this engine can be found at AutoZone, which makes it easier on ownership. Only frustration lies when you have to pull a part and match it up with similar fitting parts. Early Range Rovers have the same engine, and you can cross reference parts at stores (because anything prior to '93, stores won't be able to look up parts and numbers for you). These engines are very lightweight as well.
Serviceable?: Yes and No. Many places will claim to be able to work on your rover, but once you tell them it has a carb, they say no. Most shops nowadays only work on fuel injected engines. When it comes to the basic older engines, most new mechanics are clueless. Best bet is to find a hot-rod shop or a shop that specializes in carburetors. Timing is crucial with these engines.
Mine is paired up with a ZF (auto tranny). And I have found out that my truck leaks like a SOB. Also, my exhaust leaks at the manifold, so yea, that should probably be addressed one day.
I'm currently looking for a shop manual for these engines...but haven't been able to find one. If you find one, let me know!
-Ryan
Old April 25th, 2013, 12:21 AM
ArmyRover's Avatar
ArmyRover
Bill Ski
Like this?
http://www.landroverresource.com/35_...8_overhaul.pdf
Unknown Author
716-898-8153
Old April 25th, 2013, 12:30 AM
BEIS's Avatar
BEIS
RYAN BEIS
Originally Posted by ArmyRover View Post
Yea, I've seen that overhaul manual, but looking for part numbers associated...that's the hard part.
-Ryan
Old April 25th, 2013, 02:50 AM
Grew up on SU fed British Leyland cars. Like everything once you know them they are fine. Ask me today to sort out a pair after so many years of EFI engines and I'll be lost.
Old April 25th, 2013, 09:58 AM
I think a lot of people switch from SU's because they don't know how they work.
Old April 25th, 2013, 11:39 AM
griffman
victor jones
1984 90 V8
Hi Guys,
Over here everyone on the early cars is switching to 4-barrel carbs rather than the twin su's.
The SU's are great for economy IF they are set up correctly, but if you have some headwork and decent valves and even a mild camshaft they are next to useless.
Offenhauser and Edelbrock both make intake manifolds - then it's a choice of 390 holley or 500 edelbrock.
The edelbrock importer for the UK is a friend of mine - he is selling everything he can get his hands on for the 215/RV8
------ Follow up post added April 25th, 2013 09:42 AM ------
Hey Guys
You will all find this site useful
WWW.MEZ.CO.UK - tuning the rover V8
Written and maintained by a very knowledgeable Rover V8 Engine man.
Old April 25th, 2013, 12:16 PM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
I swapped out my side draft carbs for the Edlebrock intake and 1404 carb. The reason was that my side drafts were in need of a major overhaul (they were 25 + years old afterall). The costs for parts and to get a mechanic to tune them was almost equal the price of the edelbrock conversion.
With the conversion - I now have a carb that can be fixed with a screwdriver and parts from Autozone or SpeedUnlimited - so that is handy.
But, I am not really impressed with how the edelbrock handles off road / really bad angles. That... and when the engine is hot in the summer time - it starts really hard due to boiling gas pushing past the needle valves and flooding the carb - lots of web articles on this for variety of cars / engines - with lots of remedies proposed.
So, there is good and bad - but if you spend a lot of time on the pavement and your side drafts are giving you fits... the edelbrok will bring simpicity and zen into your life. I do not regret making the change.
(I am sometimes curious about putting good condition side drafts back on. A a comparison of worn out side drafts to new in box edlebrock is not really fair.....)
Firemanshort
1980 Stage One 109
Sterling, VA
Old April 25th, 2013, 12:49 PM
griffman
victor jones
1984 90 V8
There is an edelbrock carb part that you are supposed to fit to off-roaders to stop surging/ flooding at angles!
Old April 25th, 2013, 01:18 PM
BEIS's Avatar
BEIS
RYAN BEIS
Is this the kit?::
http://www.4wheelparts.com/Performan...5&t_pn=EDE1465
-Ryan
Old April 25th, 2013, 01:59 PM
Viggen's Avatar
Viggen
Jarrod
none
This is what happens quite often. In reality, they are the easiest carbs as they are self adjusting. Keep fluid in the dashpots and youre set. No need to worry about much. I didnt think the 3.5s got SU's, or at least Ive never seen it. Usually its ZF carbs which are fine but have many issues of their own. I put SUs (HS4 and 6) back on my MGs. Threw that Weber crap in the trash. On a breathed on motor, once youve figured out the needle and dashpot spring strength, they are fantastic. For a 3.5, I would go with a traditional 4 barrel carb for better operation at angles.
Old April 25th, 2013, 02:33 PM
LRover's Avatar
LRover
J. Michael McCaig
Yes, you want the spring loaded needles for the Edelbrock/Carter carb for off road. Drop the float/fuel level a little more than usual and add a phenolic spacer under the carb to help prevent heat build up and you have a good off-road carb set-up. Even though I switched to the Edelbrock for the 4.6, I have to say the SU's did ok off road with the old 3.5.
Old April 26th, 2013, 12:12 AM
akrockhound
Jack
1988 RHD 110
thanks for all the feedback
Thanks everyone for that short course on SU's and the Edelbrock option.
It got me on my way on another internet search.
Like always the Forum is invaluable.
Jack - Fairbanks Alaska
Wiring Fuel Pump to a seperate switch, Good or bad idea? Neil McCauley Defender Technical Discussions 4 September 3rd, 2010 05:20 PM
emissions bad news, good news artm Defender Technical Discussions 1 July 13th, 2007 09:59 PM
www.uklandrovers.com - Good or Bad? B-Kerr Misc. Chit-Chat 1 January 31st, 2007 09:09 AM
what's a good pricing guide for D90's? januconn92 Misc. Chit-Chat 4 January 11th, 2004 01:53 PM
bad bad BAD noise rover4x4 Defender Technical Discussions 11 December 12th, 2003 12:44 AM
