Stupid T-case question.... - Defender Source
Old June 7th, 2009, 10:31 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
When you run without the drum brake and drum brackets, do you have to keep the bolts in? It's been a while since I had it apart but I am going to pull it next weekend and remove it for good. I am wondering if there is an integrity issue with the bolts behind the drum that hold the pads and backplate. Thanks
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old June 7th, 2009, 12:57 PM
The bolts to the driveshaft should be replaced with shorter ones like on the front, but the rest of it you can leave off without issue. BTW I sent you a PM to see if I could buy the drum assembly off you.
Old June 7th, 2009, 04:43 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Thanks guys. I was thinking that I would cut a spacer for the d-shaft as I worry that the drum missing will make the shaft a little too short. Good to know it can come off though.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old June 7th, 2009, 05:19 PM
I few very accurate width washers on each stud would do the same thing and would save you replacing the studs.
Stupid Question.....about lug nuts excanuk Defender Technical Discussions 31 July 22nd, 2008 06:38 PM
Stupid, Stupid, Question bstraw Defender Technical Discussions 3 February 23rd, 2006 08:48 PM
Stupid question rustydefender Defender Technical Discussions 6 January 16th, 2005 03:17 PM
Stupid Question Buckon37s Defender Technical Discussions 21 April 2nd, 2004 10:03 PM
