stupid spare tire question - Defender Source
Old July 29th, 2010, 08:35 AM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
Hi,
So I finally have my new rear door installed and for some reason I'm having a hell'va time getting the rear tire on. I took all the washers and nuts off so I'm not sure what order they go back on. Also is there a trick to getting this on....never had a problem before but since I removed everything the nuts aren't lining up just perfect to get the lugs on...then when i had it on and had it tight it wobbled.
I had the two nuts and the washers on and I still had problems. Do you need to make sure the spacing out from the rear door is the same for all three posts?
Old July 29th, 2010, 12:40 PM
Grover's Avatar
Grover
Concerning the wobble, be sure the lug nuts are not bottomed out on the studs. Adjust the nuts behind the wheel to move it out, this will leave less thread exposed for the lugs. This is what happened to mine.
Good Luck...
Old July 29th, 2010, 12:41 PM
Campbell's Avatar
Campbell
Rich Campbell
Thanks Grover....that's what it was one was bottomed out.
spare, spare tire, tire
ST Spare Tire Mount Question 97-D90-736 Defender Technical Discussions 0 May 12th, 2010 10:28 AM
Stupid, Stupid, Question bstraw Defender Technical Discussions 3 February 23rd, 2006 08:48 PM
swing-away spare tire carrier D90/D110 rvrnut110 Wanted 0 November 12th, 2005 06:19 PM
Spare Tire Cover (Stiffback?) Wanted D90JMUR Wanted 3 September 29th, 2005 05:36 PM
Safari Gard spare tire carrier Cyborg Wanted 0 July 4th, 2004 07:39 AM
