Stupid question - Defender Source
Old August 4th, 2014, 09:21 PM
Kdawg97m3
Kristian
1994 D90
Stupid question
So I bought a cigarette lighter for my open port. Want the car stock. The lighter won't fit?? There is this white collar around the port..does this mean it won't take a lighter or did I get the wrong one? Thanks
Old August 4th, 2014, 09:38 PM
post photos ... you description sucks
Old August 4th, 2014, 09:45 PM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
X2
Make sure it's not the protective sleeve on the lighter
Old August 4th, 2014, 09:51 PM
Kdawg97m3
Kristian
1994 D90
Old August 4th, 2014, 09:55 PM
rankar's Avatar
rankar
That looks like an adapter. Pull it off, or twist then remove
Old August 4th, 2014, 10:00 PM
genie90's Avatar
genie90
Jay Geaney
1994 D-90 ST #282
Yeah- that's not stock. Someone might have tried to transform the UK cigar lighter into a US cigarette lighter.
Old August 4th, 2014, 10:02 PM
rankar's Avatar
rankar
Exactly. If that white plastic doesn't come off, you've got the wrong one.
Old August 4th, 2014, 10:26 PM
Kdawg97m3
Kristian
1994 D90
Good call pulled white piece out and cig lighter slides right in. Now the port is loose so I need to pull it out and See if I can make it tighter. Is there a way to do that?
Thanks as usual my friends.
This adapter is used to make my car charger stay out!!
stupid is as stupid does... kevincdoyle Defender Technical Discussions 0 May 11th, 2014 02:21 PM
Stupid Is As Stupid Does Jonesy Misc. Chit-Chat 16 May 21st, 2012 06:54 PM
Stupid Question.....about lug nuts excanuk Defender Technical Discussions 31 July 22nd, 2008 06:38 PM
Stupid, Stupid, Question bstraw Defender Technical Discussions 3 February 23rd, 2006 08:48 PM
Stupid Question Buckon37s Defender Technical Discussions 21 April 2nd, 2004 10:03 PM
