Stupid cooler questions - Defender Source
Old April 4th, 2014, 05:21 PM
Are radiators and oil coolers really any different other than capacity? I read some oil coolers have some sort of value to block flow until the oil warms up (like a thermostat) but I think this is an advanced feature.
I need to find a small cooler for my electric 109 project and want to make sure I don't get the wrong thing. If anyone has suggestions, it would need to be something like the tranny cooler on a 97 D90 or a little 5x8 jobbie (1/2 ports).
tia
charles
Originally Posted by pendy
I'm here for the D's
Old April 4th, 2014, 05:42 PM
Oil coolers are designed to dissipate lower amounts of heat per unit time and operate at much higher pressures than radiators.
Water Radiators are designed to dissipate more than 4 times the heat of oil coolers. This is why radiators have huge amounts of surface area compared to oil coolers.
The question is, what liquid are you cooling? If water, you need a radiator. If oil, you can get away with using an oil cooler. However, if you use an oil cooler for electric motor cooling then you are operating at a quarter of the efficiency of using a real radiator.
Old April 4th, 2014, 05:51 PM
Water/coolant.
The truth is I don't know how much cooling it needs but assume anything is better than nothing. So what would you do if you needed a small radiator?
Old April 4th, 2014, 06:05 PM
Originally Posted by cgalpin View Post
Water/coolant.
Get one from ebay for a 1100 or 1300cc bikes like a Suzuki Hayabusa, Honda CBR1100, or other water cooled motorcycle.
If they are too big, then look at the 600cc bikes
motorcycle parts are an awesome source of everything you need for smaller versions of automobile parts. This is very commonly done on locosts and will save you lots of money.
Used parts are plentiful because several thousand Americans die on them a year and over 120,000 non-fatal motorcycle injuries are treated per year, and each injury usually corresponds to one messed up bike.
200tdi oil cooler / oil cooler line thread question dave_lucas Defender Technical Discussions 7 September 26th, 2012 11:56 AM
Stupid Is As Stupid Does Jonesy Misc. Chit-Chat 16 May 21st, 2012 06:54 PM
stock adapter between oil cooler and oil cooler lines dave_lucas Wanted 3 December 23rd, 2009 03:33 PM
More Oil Cooler Thoughts/Questions.. LRNAD90 Defender Technical Discussions 8 February 25th, 2008 01:30 PM
Stupid, Stupid, Question bstraw Defender Technical Discussions 3 February 23rd, 2006 08:48 PM
