Stumped and Frustrated: 3.9 V8 into a ROW 110 - Page 4 - Defender Source
Old July 15th, 2015, 09:41 PM
Bleah just got home. Kent lives diagonally across the other side of DC from me so longish slog home.
The issue was the integration of a 95 RRC ECU harness to an old 4 banger wiring ( air quotes) "harness" full of PO hacks.
We went thru things one step at a time. Got power to the harness then the fuel pump then the ECU. Found good places to tap switched power.
Sorted out a bad ignition module wire. Lit the fuse and it went bang.
85Red110's Avatar
85Red110
Kent
1985 110 3-door
It was a combination of MANY wires needing to be connected to the correct places. Im not nearly knowledgeable enough about "modern" engines (ie. anything fuel injected) to be able to adequately explain in further detail.
Bill will have to chime in. I cant thank him enough for all his help.
Edit: Looks like he beat me by a few seconds
1985 Land Rover 110 3-door ST
Old July 15th, 2015, 09:52 PM
Having had so many problems with my V8 and seeing the problems others are having that sound so similar but aren't....makes it tempting to go diesel...
Old July 15th, 2015, 10:07 PM
Honestly it wasn't really anything all that bad. Part of the process of any engine swap.
Old July 15th, 2015, 11:17 PM
nice!
Old July 16th, 2015, 02:47 AM
gchinsr's Avatar
gchinsr
Greg Chin Sr
1996 Discovery 5 Speed
Kent
Great to hear you guys sorted this out. I am happy to see you back on the road soon. Enjoy mate.
Cheers,
Greg
Old July 16th, 2015, 05:22 AM
Great job guys. Looking forward to seeing it tonight!
Originally Posted by pendy
I'm here for the D's
Old July 16th, 2015, 07:21 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
That's great news!
I wonder if a 87-88 RRC harness would have made it simpler since it does not have the bells & whistles of a 95. Just a thought for future conversions by others.
Old July 21st, 2015, 11:22 AM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Well, we got the engine running, but after 15-20 seconds it chokes itself out like there is too much fuel being pumped into the cylinders. Stock injectors are in. Brand new spark plugs are caked with black carbon. What's the timing supposed to be set at? How many degrees advanced or retarded?
Old July 21st, 2015, 11:32 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
"Landrovered" made a nice post 8 years ago: http://www.defendersource.com/forum/...tml#post139347
Thinking I'm closer to 8 degrees with the Mallory.
Old July 21st, 2015, 11:47 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Book says 6 Before.... I think I'm around 10-12... but I have an aftermarket cam.
Does it fire up straight away or struggle?
I wonder if your external fuel pump is over fueling. I'd test fuel pressure and both the coolant & fuel temp sensors. Also your MAF may need adjusting too. All three of those can cause a rich running condition.
Old July 21st, 2015, 12:11 PM
Sounds for sure like a bad or disconnected fuel pressure regulator. Check the vacuum line at the back of the plenum cover that goes down to the regulator
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old July 21st, 2015, 12:14 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
http://youtu.be/YxTWPr1XZ4g
Old July 21st, 2015, 12:42 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
In that video, the only input is when my dad pulls the throttle.
Timing is in range, and all vacuum lines are good. I suppose next step would be to replace the fuel pressure regulator.
Old July 21st, 2015, 12:57 PM
No exhaust = no back pressure= runs rich. I think before you over think this you should install an exhaust. I have had major exhaust leaks on rover v8's and the trucks ran much smoother once an exhaust was installed.
Old July 21st, 2015, 06:10 PM
I agree get an exhaust on it before jumping to conclusions, but you should also stick rover gauge on it and see what it says.
Old July 21st, 2015, 06:18 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
We will be trailering it down to an exhaust shop within the next few days.
110, v8
Stumped- 300 Tdi running hot- skrufy Defender Technical Discussions 6 April 23rd, 2014 08:40 PM
Rear Defroster dead- stumped. J.P. Defender Technical Discussions 1 November 10th, 2012 05:17 PM
Frustrated..... Worldrover1 Defender Technical Discussions 5 June 21st, 2011 02:44 PM
Still frustrated - Can't pass 3400 rpm ScottYates Defender Technical Discussions 5 January 17th, 2007 09:16 PM
stumped rover4x4 Defender Technical Discussions 5 April 1st, 2006 09:07 AM
