Stumped and Frustrated: 3.9 V8 into a ROW 110 - Page 3 - Defender Source
Old July 7th, 2015, 10:23 AM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Originally Posted by Naplm00 View Post
bad coil? try a spare?
Need to go buy a spare to test. This coil worked as I drove the truck into the garage to begin the swap.
1985 Land Rover 110 3-door ST
Originally Posted by 85Red110 View Post
White/black connected to neg on coil. White wire has power.
White connected to positive on coil, still no fire.
That is not explaining where all the wires go..... Explain where ALL the wires go.
Old July 7th, 2015, 10:27 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Attachment 124516
Test for spark from the HT lead.
Old July 7th, 2015, 10:28 AM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
One positive, one negative to ign amp module. White/black from neg into harness at MAF sensor loom. White from positive to connector on firewall (ignition switch)
------ Follow up post added July 7th, 2015 10:31 AM ------
No spark. I guess somehow my coil decided to stop working at some point? This is ridiculous.
Old July 7th, 2015, 10:53 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Did you put a black wrap on the solid white that you moved to the positive side or is that a different wire you hooked up?
Old July 7th, 2015, 11:01 AM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
It's a black wrap
Old July 7th, 2015, 11:03 AM
Okay. Disconnect the wire to the EFI system as you are not sure what that is. Let's get spark first.
1) Verify there is +12V to the coil while cranking is happening.
2) With a spark plug loose and connected to an ignition wire, hold the body against a good solid ground and crank. Is there spark?
If not, then test first the coil, then the ignition module as per the workshop manual.
Old July 7th, 2015, 11:05 AM
Obviously check other things as well. All HT leads are properly seated. Assume distributor is installed properly and cap and rotor seated.
Old July 15th, 2015, 03:43 PM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Kent... any updates?
Old July 15th, 2015, 03:45 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Coincidentally, Mr. Bill Adams just arrived at my house to help troubleshoot. Updates will follow....
Old July 15th, 2015, 03:59 PM
phoenix37's Avatar
phoenix37
john
Can you take a picture of him? Love to know what he really looks like. I always just picture his avatar.
Old July 15th, 2015, 04:07 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
His avatar is surprisingly close....
Curmudgeon ?
------ Follow up post added July 15th, 2015 04:11 PM ------
Shayne had posted a hand drawn picture showing the 5 wires that need to be connected to make it work.
The key to spark is to connect the white wire that runs the the coil to the ignition switch run position. There will also need to be a jumper from that same post over to the ecu.
Old July 15th, 2015, 04:12 PM
phoenix37's Avatar
phoenix37
john
thats hilarious...
Old July 15th, 2015, 04:13 PM
The Dro
Dro
1988 Ninety
When you get done you can swing by my place.
Old July 15th, 2015, 04:59 PM
I guess it is easy to forget that most haven't met him
Bill, if you are reading this, I need one of those fancy delay timer relays for the RRC EAS if you have any.
Originally Posted by pendy
I'm here for the D's
Old July 15th, 2015, 06:48 PM
Beer's nearly gone. No wonder he looks grumpy.
Old July 15th, 2015, 07:11 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Success! Bill is indeed a mad scientist.
It's loud as hell with no exhaust.....
Old July 15th, 2015, 07:15 PM
Sweet! I lied, this is what Bill really looks like
Old July 15th, 2015, 07:17 PM
psykokid
Jake
1997 Disco
And the problem was? Inquiring minds want to know!
110, v8
Stumped- 300 Tdi running hot- skrufy Defender Technical Discussions 6 April 23rd, 2014 08:40 PM
Rear Defroster dead- stumped. J.P. Defender Technical Discussions 1 November 10th, 2012 05:17 PM
Frustrated..... Worldrover1 Defender Technical Discussions 5 June 21st, 2011 02:44 PM
Still frustrated - Can't pass 3400 rpm ScottYates Defender Technical Discussions 5 January 17th, 2007 09:16 PM
stumped rover4x4 Defender Technical Discussions 5 April 1st, 2006 09:07 AM
