stumbling under load when hot..? - Defender Source
Old May 5th, 2008, 08:57 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
Guys, my truck's been running great for the past two months. I've began to notice in the past week, and it was really bad today (70 degrees outside), that about 5 minutes or so after my engine gets up to temp, it gets very rough off idle up to about 2k rpm and will stall unless I slip the clutch to let get up to speed. Stumbles under load under 2krpm. Revving/power at over 2000 rpm is fine.. I'm assuming its something gettign hot and then mal functioning. Ignition amp? Fuel press regulator?
Anyone seen this before?
Any ideas??
It may be time to install the Toddco ignition amp/coil kit!?
thanks!
~Steve
hot stumbling, stalling.. (continues) revtor Defender Technical Discussions 4 February 10th, 2009 01:27 PM
Stumbling during acceleration and load Bozman Defender Technical Discussions 8 June 14th, 2006 08:02 AM
ST rear load space matt in SW? Seriesman Defender Technical Discussions 6 November 2nd, 2004 12:44 AM
Playing with Rovers, guns and a hot blonde in Africa wicks Misc. Chit-Chat 1 February 21st, 2004 09:31 AM
Superlift ORV Park in Hot Springs, Arkansas Nov. 20-23 Joe B Trips, Trails and Events 5 November 12th, 2003 10:07 AM
