stumbling idle resolved - Defender Source
Old September 4th, 2015, 04:27 PM
ezzzzzzz
Mark Garrenton
I had an issue with my '99 DI and thought I pass this on. At first I had fuel pressure of 28lbs key on engine off. I replaced the fuel pump (E3270). I also pulled the fuel rail and swapped out the fpr and installed used bosch 0280155746 yellow injectors (assuming one or the other could be failing after all these years. I pulled injectors from 2 late 860(?) models. To get a total of 8 I pulled from a non-turbo and turbo as the p/n is the same. There was a rubber dust ring that I removed before install. I'll be the first to say that I anticipate better performance when I do something like this. It could be sit-of-the-pants but the truck does seem to idle and accelerate better with these bosch injectors. That could be for any of the replaced though. I filled the tank and zeroed the trip meter. We'll see if there is any improvement in mileage.
idle
95 RRC 3.9 - stumbling at just above idle corrumpu Defender Technical Discussions 8 December 20th, 2014 06:29 PM
Idle Control Valve (idle stepper motor) fleabus For Sale - Parts 3 June 28th, 2009 12:13 AM
Rough idle, stumbling, dying.... revtor Defender Technical Discussions 9 January 10th, 2008 04:28 PM
Stumbling during acceleration and load Bozman Defender Technical Discussions 8 June 14th, 2006 08:02 AM
Chris, Verizon Email Issues Resolved!!! Glenn_Guinto Support & Suggestions 1 March 5th, 2004 09:44 AM
