stuck wheel bearing - Defender Source
Old August 31st, 2009, 02:23 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
stuck wheel bearing
The damn inner bearing is rusted onto the stub axle. I got the hub off but can't make the inner bearing budge. I'm about ready to try an bunch of M80s to knock it loose. Any thought? I don't think a puller will work with the open axle shaft.
Old August 31st, 2009, 02:28 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Use a puller. I would put something over the axle hole for the puller to go against. Or you can cut the outer shell off and remove the rollers then heat the inner piece with a torch.. It should just come off then with a little tapping of a hammer
Legend in My Own Mind.
Old August 31st, 2009, 02:44 PM
yup, what randy said. Or you can use a thin cutoff wheel to carefully slice the bearing race.
Old September 1st, 2009, 12:02 AM
chrisconnie's Avatar
chrisconnie
Adam Hairston
97 LE #127/300
You can borrow/rent a puller from Autozone or someplace similar. I had a stuck bearing on a different vehicle similar to what you describing and a slidehammer did the trick.
Old September 1st, 2009, 12:16 AM
jorge's Avatar
jorge
JORGE ESPINOZA
97 ST WHITE MODS SUPERCHARGED
Gentlemen check your bearings . Had mine checked last week and all bearings had rust . The D90 has new bearings and greased with marine lube all around and is driving tighter and a little quieter .
Old September 1st, 2009, 09:02 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
In my experience after you pack them drive the truck for a week and then check them again. a week or so lets the greese settle and move around in there and they can become loose again. Because the initial packing you may think the washer and nut are tight because the grease is packed in there all tight and hasn't made its way into the bearings and hub yet to settle.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old September 1st, 2009, 09:04 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Did you check you bearings on the streets of alphabet city?
Marine lube? I was using multi-purpose synthetic grease. Any differences?
Just to refresh my memory, the inner axle nut you just snug up but the outer one you really wrench on, right?
Do I need to change the Races? It's such a bitch to hammer those out
Old September 1st, 2009, 09:22 AM
A machine shop will sometimes change the races while you wait. I don't like drifting them out because its so easy to mar the inner surface of the hub, and stuff like that drives me nuts.
Old September 1st, 2009, 03:22 PM
ini88's Avatar
ini88
Daniel Marcello
i've changed my front bearing on the street before. People look but whatever. Its great too because you can go to the bar like 4 feet from you and get drunk while your truck sits there with its wheels off.
Use Marine or Mobil one grease. I have used cheap grease in the past and it didn't turned out too well. put the large seal washer in snug up next to the bearings, then the inner nut (tighten it down but not too much. the hub should still move back and forth easy, but don't make it too loose), tab washer, outer nut, fold tabs over inner and outer nut. Change the races if you can. use a big hammer and soft drift and give it one good tap. You need help? i can come over and help you out, I've done them so many times its like second nature to me.
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old September 2nd, 2009, 04:43 AM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi Stephen, I had a similar problem the inner bearing failed due to water ingress, it sized and spun the inner race against the stub axle and friction welded itself there.
there was a real bad screeching noise for 5 mins and then it was gone, i then found i was unable to remove the hub cause the inner bearing was sized.!
anyway I smashed up bearing with hammer & small chisle cut through 99% of inner race with laser disc in grinder then gave the inner race a sharp tap with a cold chisle and it came off.
I cleaned off stub axle & refitted new bearings with the intention of replacing the stub axle when I had more time but it was still there 6 years later.
To prevent that happening again I used Amsol water resistant grease it's twice the price of my normal grease but it does not absorb water at all. top stuff.!
I use it for everthing now.
regards
Gren
regards
Gren
Old September 2nd, 2009, 09:34 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Seems I need to upgrade my grease. Everything in there was rusted solid. Then again, it's the original job from the factory, never opened up the rear hubs before. Guess that's what I get.
Old September 2nd, 2009, 10:01 AM
I've never seen a set rust out... How did you know there was a problem?
Old September 2nd, 2009, 10:05 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
There started be this intermittent noise and a mild vibration going around corners. I noticed that it was worse when the wheel was weighted. I had a bearing fail a couple years back on the highway and it was the same symptoms. It took a long 3/4 extension through the hub socket and my brother and I both yanking on it to break the outer nut loose.
wheel
wheel bearing D90user Defender Technical Discussions 15 April 17th, 2006 09:35 PM
LT230 questions and concerns - bearing failure. kiphartzell Defender Technical Discussions 4 January 13th, 2006 01:56 PM
Rear wheel bearing damage potential?? Neo Defender Technical Discussions 8 November 28th, 2004 11:58 AM
Front Wheel Bearing replacement flippedrover Defender Technical Discussions 11 December 21st, 2003 11:44 PM
