Stuck U joint circlips - Defender Source
Old May 2nd, 2011, 01:45 PM
Santiago Montenegr's Avatar
Santiago Montenegr
Santiago Montenegro
98 110 CSW 300 TDi
Gosh, I hate them. Anyone have a black majik trick to get them out?
Old May 2nd, 2011, 01:54 PM
Circlip pliers.
Not sure what you are doing to make it difficult.
Old May 2nd, 2011, 02:04 PM
Santiago Montenegr
Santiago Montenegro
98 110 CSW 300 TDi
Me? I'm only trying to make them surrender a sloppy U-joint
Two of them worked as expected. But the other two...
Broke two circlip plier tips yesterday, and them clips did not budge. Don't look rusted, or anything, but they simply refuse to give in.
BTW, isn't that "normal" (as in Rover-normal) for you? Every time I've changed a LR U-joint it has been an ordeal to get them out.
Old May 2nd, 2011, 02:26 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
are you giving them a smack with a hammer and appropriately sized socket before trying to remove?
Old May 2nd, 2011, 02:35 PM
Yes, hammer the caps inwards to make sure there is no pressure on the clip and give a spray of penetrating oil.
No, Rover joints have been the same to change as any other. They are just regular Spicer U-joints.
Old May 2nd, 2011, 02:41 PM
I have had good luck with a small punch to get them started. Put it in the part where the circlip plairs would go and give it a couple taps with a hammer.
Old May 2nd, 2011, 02:51 PM
stick the joint in a vise with a socket on top of one circlip and clamp until there is no pressure on it (as mentioned). should come right out.
Old May 2nd, 2011, 02:53 PM
Santiago Montenegr
Santiago Montenegro
98 110 CSW 300 TDi
Caps pressured inside at no avail. Will try the punch after work and report accordingly.
Thanks, guys!
Old May 2nd, 2011, 06:43 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Once you hit the cap with a socket.....get a bigger socket that just fits the cir-clip and smack that too! it seems to break the funk loose.
clips
Rear Ball Joint Buckon37s Wanted 4 April 9th, 2006 06:54 PM
CV joint gone bad? Hans Defender Technical Discussions 5 December 4th, 2005 04:24 PM
Help - Stuck in water for 3+ hours mfreeman17 Defender Technical Discussions 2 May 25th, 2005 08:10 AM
Rear A-arm Ball Joint ronward Defender Technical Discussions 4 February 25th, 2004 08:53 AM
rear ball joint mattdh Defender Technical Discussions 3 October 13th, 2003 04:28 PM
