stuck in the middle of no where, need help - Defender Source
Old September 8th, 2006, 11:13 PM
steved90
steven melnyk
hi gang,
was headin up north, lots of rain, then no power, had to pull off the side of road, batt good, think some water got innear the relays an fuses in the center colum, is in a local shop tonight and girlfriend and i are in a motel room she is not happy, what advice can igive these mechnics?
anyhelp would be great, sux getting stuck, with the lady.
i wouldn't mindso much...
Old September 8th, 2006, 11:18 PM
So did the engine jus shut off? Did all the electrical die? What happened? would it try cranking?
Old September 8th, 2006, 11:21 PM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
Hi Steve...by no power do you mean absolutely none? no cranking, no horn no lights? if you have nothing then I would check battery leads and connections first...
good luck and keep us posted
George
Old September 8th, 2006, 11:27 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
I would check:
Distributor for water ingress...water under the cap
coil connections
Plug wires
ECU and EFI relays for water ingress
Those are the usual suspects when things die after getting wet.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old September 8th, 2006, 11:56 PM
steved90
steven melnyk
still have power to everything, will not turn over or even cranck, just a tap tap tap not click, but tap from thr relays in the center colum.
Old September 9th, 2006, 09:40 AM
steved90
steven melnyk
just talked to the mechanic and the sad thy can't get the computer to read, and that the wipers r not working, they aso said it would be days before they could get parts?//
any ideas? they want to charge me an arm and a leg to tow it home!
Old September 9th, 2006, 10:36 AM
Rod Hayward's Avatar
Rod Hayward
Rod Hayward
95 D90 Green #2288
What year is your 90?
Funny that the mechanic is already talking about how long it will take to get parts when he has yet to diagnose the problem!
I'd go through the list Rob posted above. I'll bet you will find the problem, and you can fix it yourself.
Good luck
p.s. If you're stranded and need someone to wire you some beer money, let us know.
Old September 9th, 2006, 10:37 AM
redrover
Guest
Posts: n/a
steve look at the 15 amp fuse -top right inside the center console bank. Mine loosened and eventually fell out after I had pulled the console out for a project. I know you had your console out this summer. It is easy to snag a few of the fuses when you work the forward end of the console back into place. If the fuse is blown or out you will hear fuel pump, radio etc-but no dash lights,wipers or ignition. Hope you get on the road soon. Is the top keeping you dry? How did the paint work turn out? JP
Old September 9th, 2006, 06:46 PM
steved90
steven melnyk
just got back guys (towed back)
cost me an arm and a leg, it is (i think the ECU relays) center dash, couldn't find them out in the middle of nowhere where we were. i think that is it. i will get deeper into it tomorrow, sitting, and relaxing and havin a beer at home now. looks like water got in by the center consol relays??
oh yeah i need beer money wired to me ASAP!!!
JP, the truck looks great! keeping me dry? enough i guess.
oh yeah did i mention i needed beer money??
or you can just send me beer, capital city brewery island wheat!! it rocks!!
Old September 11th, 2006, 09:47 AM
steved90
steven melnyk
i am home trying to get the rig going, i thought that if i replaced the relays it would start? not yet. anyway, the fuel pump is not going on i have no brake lights and the wpers won't go on. what else should i be checking???
Old September 12th, 2006, 01:26 PM
Gkase's Avatar
Gkase
George Kase
Steve,
how's it going? I'm going to suggest it is a corroded or loose ground...let us know.
D-90 stuck in Park, Won't start. HELP!!! brianosaurus Defender Technical Discussions 9 December 12th, 2007 09:45 AM
Thermostat Stuck Open? johare Defender Technical Discussions 12 March 16th, 2006 08:58 AM
Defender 90 front middle seat D-90-Girl Wanted 2 August 1st, 2005 11:52 PM
Help - Stuck in water for 3+ hours mfreeman17 Defender Technical Discussions 2 May 25th, 2005 08:10 AM
Stuck In Iraq javelinadave Misc. Chit-Chat 5 April 12th, 2004 07:53 PM
