stuck in knoxville, TN - Defender Source
Old February 1st, 2008, 12:50 PM
Angry stuck in knoxville, TN
I was on my way to Fort Knox for training this morning, and my right front bearings seized up on me just outside Knoxville. I'm at Land Rover Knoxville now, and after much effort, they have been able to pull the spindle and axle. looks like the cv axle shaft (stupid 10 spline) broke, causing a chain reaction. the remainder of the axle shaft is froze inside the spindle, and if they can't come up with a quick part source, anybody know the quickest wayt to get a replacement CV shaft and spindle? I'm supporting to report for duty tomorrow morning, and I'm guessing I'm hosed.
Old February 1st, 2008, 01:04 PM
Fedex from RDS. I guess you probably wont arrive with the truck, probably better to rent a car than FTR.
Old February 1st, 2008, 01:06 PM
Pull the front axle apart, Put new bearings on with a lot of grease on the old spindle, lock the diff and drive there in 2wd.
It will make it.
PS you can press the axle out of the spindle.
Old February 1st, 2008, 01:50 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
you could always look up TLR think their website is tntlr.com
Old February 1st, 2008, 01:55 PM
Thanks all. checking options. If there's anymore, throw them my way.
Old February 1st, 2008, 02:15 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Bill is a good dude & he is close to you.
tlr 866 857 7687
I have bought some stuff from these peeps! Very nice as well.
Outback Off Road Center
250 East 20th Street
Chattanooga, Tennessee 37408
Phone: (423) 634-0841
Old February 1st, 2008, 02:24 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Yeah, if TNL can't help you out, then the 2WD route is the way to go assuming they can get it apart. In fact, that might be worth it anyway, you can swing by TNLR and get the parts if they have them and take care of it at Fort Knox.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old February 1st, 2008, 02:28 PM
so for the 2wd option, is it just pulling off the driveshaft or do both axles have to be pulled?
Old February 1st, 2008, 02:37 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
you may want sleeve the axle with a piece of PVC pipe and put it back together. It wouldn't rattle around as much and won't scrape the inside, just the PVC it sits in.
Pull the front driveshaft out. and lock the diff in High so all the power goes to the rear wheels.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old February 1st, 2008, 02:41 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
drive shaft you should be fine if Bill has your stuff I would KINDLY ask him to fix er up for you!!
Here I am worried about a guy making it to formation when there are still perfectly good roadside repairs to attempt
Old February 1st, 2008, 02:45 PM
Thanks all, but I wouldn't consider it roadside repairs at this point. The wheel actually seized, and inspection revealed the outer locking nut, and races welded to the spindle. they got those out, but the outer half of the cv shaft broke and is seized in the spindle, and they can't get it out (allegedly).
Old February 1st, 2008, 02:48 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
dude call bill ask him if he has the parts! If he does get them or take it to him.
Old February 1st, 2008, 03:22 PM
Antichrist's Avatar
Antichrist
Tom Rowe
I haven't personally looked at a '93, and don't have my '93 manuals here, but I would, if possible, disconnect the front propshaft and pull the front axle shafts. The only thing I'm not sure of is if not having the axles in would cause any other issues. But I think it would be ok. By "spindle" I assume you mean the stub axle, that the hub nuts go on. A new/used stub axle should be pretty easy to find locally I would think, especially if they are the same as my D90. A D1 stub axle would work I think.
I just took a look, http://www.tntlr.com/axles.htm and it looks like he has front axles, but OUCH! on the price.
He also has the stub axle. Listed anyway.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old February 1st, 2008, 03:28 PM
Thanks all. Rovers North has parts on the way. RN and Bill at TLR couldn't get anything to Knoxville until Monday, so I'll have to rent and come back for it next week. 24 spline upgrade is moving up quickly in the que.
Old February 1st, 2008, 03:33 PM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
I know Tom the manager at LR Knoxville and my dad buys from him and has his 90 serviced there all the time. If you need any pull with them let me know. Good luck.
"I race cars, play tennis, and fondle women, BUT! I have weekends off, and I am my own boss." - Arthur
Old February 1st, 2008, 06:45 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Mark if you want to go 24 spline you should maybe think about replacing the spindles to the later style. This may be the time to change out depending what CV's and inner axles you want to run. If you call I'll try harder not to miss your call this evening. I have the stock needed parts here also, used. But not all of the newer style bits needed. Might as well go vented rotors now as well. Thinking out loud here.
JP
legend in my own mind
Old February 2nd, 2008, 08:35 PM
Pendy,
I really appreciate it, but the parts from RN are already on there way to LR Knoxville. I'm in training for 14 straight days from 7am-10pm, and I still have to find time to do the 10 hour round trip to drop off this rental and pick my rig up and return in the next few days.
If this happened back in Charlotte, I would have towed it home, and done the conversion myself, as home this is not a hard job. It KILLS me that I"m spending $1200 to repair 1 wheel with 10 spline crap, (I could have gotten an ARB and 24 spline conversion parts for not much more) but this is my 1 shot to get this required schooling out of the way so I can make Major before going back to the sandbox. I retire right after we come back in 2010, so it just sucks.
LR Knoxville proved to be a very good service dealership though, for what it's worth.
I'm going to make out the parts list later this week if I get the time with Keith, and just start gathering over the next few months until I have enough to do it. Or just wait until 2010.
When is this frigin' war going to end? It's really interfering with my Land Rover experience.
Old February 2nd, 2008, 08:54 PM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
First and foremost, Thank you for your service mark! Hell, come pull some parts off my rig!
Old February 2nd, 2008, 08:58 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Dude, I would have loaned you an axle. That suxs!
I hear you on the war-you guys know better then the rest of us.
Carry on.
D-90 stuck in Park, Won't start. HELP!!! brianosaurus Defender Technical Discussions 9 December 12th, 2007 09:45 AM
Thermostat Stuck Open? johare Defender Technical Discussions 12 March 16th, 2006 08:58 AM
Help - Stuck in water for 3+ hours mfreeman17 Defender Technical Discussions 2 May 25th, 2005 08:10 AM
Brake Lights Stuck ON RoverWrecks Defender Technical Discussions 4 August 21st, 2004 11:26 AM
Stuck In Iraq javelinadave Misc. Chit-Chat 5 April 12th, 2004 07:53 PM
