Stuck in 4WD Diff lock - Defender Source
Old October 18th, 2016, 11:49 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Never encountered this before... the LT-230 in one of our 110's is stuck in 4WD Diff Lock.
This is a low mileage Ashcroft reman 1.4.
Got underneath and moved the linkage with a pry bar to the inside and heard it click (out of diff lock ?), but the case stays in diff lock.
Can these things get stuck?
Am going to pull the Left floorboard and tunnel tonight for a closer inspection.
RDavisinVA
Old October 18th, 2016, 12:04 PM
The Dro
Dro
1988 Ninety
I hope the click wasn't a part breaking.
When I had issues on one of my DI's... It helped moving the truck a few inches back and forth.
Old October 18th, 2016, 12:19 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
I've had to reverse a good bit before to disengage diff lock.
Old October 18th, 2016, 12:32 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
X2 on backing up. Mine can be a little persnickety that way.
Land Rover 110
Old October 18th, 2016, 12:34 PM
especially if bound up from driving on dry pavement locked since MAR
Old October 18th, 2016, 12:55 PM
Yorkie
Mark Whitehouse
1989 D90
I had the same issue, reversed a little and it popped right out.
Old October 18th, 2016, 02:17 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
If none of the above suggestions work, put the entire truck up on jack stands, start it up, put it in 2nd gear, and hold the lever to the right while the drive train is spinning. If it still won't let go, jump on and off the throttle while holding the lever towards unlock.
Old October 18th, 2016, 03:11 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Thanks muthalikkas!
RDavisinVA
Old October 18th, 2016, 03:51 PM
The Dro
Dro
1988 Ninety
Originally Posted by rdavisinva View Post
Thanks muthalikkas!
Where you able to "unstuck" the diff lock?
Old October 18th, 2016, 04:04 PM
Broodster's Avatar
Broodster
K L
1989 90 V8 County
The diff lock carrier might be stuck on the diff lock switch, try screwing it out a bit and see if it frees up, especially if you did not adjust it before putting into the truck.
I have rebuilt a few of these and that is usually the first problem.
Old October 18th, 2016, 04:11 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Diff lock worked perfectly for over a year, so switch is not a likely culprit, but won't completely rule it out, thanks.
------ Follow up post added October 18th, 2016 04:12 PM ------
Not yet, will try to back it up for a while.
RDavisinVA
steering box lock & adjuster nut- stuck PMKColorado Defender Technical Discussions 2 April 25th, 2011 03:48 PM
Diff and tcase plugs are stuck smob Defender Technical Discussions 7 March 19th, 2011 04:22 PM
stuck in Maine: Need diff or front driveshaft ini88 Defender Technical Discussions 4 September 12th, 2009 12:00 AM
Coolest factory name for a 4wd ever? Hans Misc. Chit-Chat 22 January 12th, 2006 12:04 PM
