Stuck! Fuel system bleed! - Defender Source
Old May 31st, 2013, 08:22 PM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
I am replacing the fuel filter and it seems like the manual lift pump ain't lifting squat! Been pumping the damn thing for 30 min and hasn't drawn anything in to the filter.
I'm following the workshop manual direction cross checked with my Haynes manual and the advice Red gave me.. Still outa luck. No prime, no drivey!
Thx!
Old May 31st, 2013, 08:32 PM
Are you feeling any resistance when you pump? Thinking the lift pump cam is probably not in the right position.
Turn the engine over. If you have the bleed screw loosen diesel will dribble out.
Old May 31st, 2013, 08:35 PM
josh-man's Avatar
josh-man
joshua
I feel zero resistance. Can the cam position be changed? Or is the pump dead?
Old May 31st, 2013, 09:24 PM
josh-man's Avatar
josh-man
joshua
All set many thanks. Red is right. Bleed bleed bleed.
Ps you CAN fill a 2 piece fuel filter with diesel to help prime! Messy as all hell but I bet it stayed 3/4 full before it was tightened on there!
Old May 31st, 2013, 10:43 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
I have always filled mine with ATF.
Old June 1st, 2013, 03:15 PM
Frank84
Frank Battersby
95 D90
A brake vacuum bleeder works well for drawing fuel through too.
'95 Soft Top
'89 Classic Tdi
Bleeding TDI Fuel System isleofbones Defender Technical Discussions 5 October 21st, 2010 04:47 AM
Calling all diesel guys - Biodiesel??? cbass Defender Technical Discussions 47 January 31st, 2006 11:18 AM
