Stuck Drum - Defender Source
Old September 5th, 2016, 06:06 AM
jncilliers
Jaco
1988/110
Stuck Drum
Hi All
I have a question about a stuck drum on my defender. I figured it was time to replace the brake shoes so I slacked off the brake adjusters. The drum screw was properly stuck so ended up drilling the head off. With a lot of penetrating fluid and hammering the drum is still solidly stuck with no movement. The drum turns freely at the moment.
Does anyone have any ideas for me?
Old September 5th, 2016, 06:52 AM
Contractor's Avatar
Contractor
Will
1969 IIA
It should have a hole in it on the side that is perfect for a 3/8 bolt. Thread that in the hole and tighten it up, the drum should pop off.
Old September 5th, 2016, 07:02 AM
Hammering the drum (but not the studs) is the traditional method. Also the inner/ back edge of the drum.
If you have threaded hole on your drum (not all do), inserting a bolt there and turning can help. If you only have one threaded hole, turn a little but before hammering the opposite side.
And of course heat....
Old September 5th, 2016, 10:05 AM
Heat it up a bit with a torch?
Old September 5th, 2016, 10:25 AM
DocB
David
1989 D110
Had this issue 2 weeks ago myself. I used the threaded hole next to the drum screw, fitted a bolt into it, and went to work. Once I noticed the drum starting to budge, I finished it off with a hammer and a block of wood. I'd be careful to hit the drum straight on with a metal hammer, wouldn't want to crack it.
Old September 5th, 2016, 10:28 AM
BlackField's Avatar
BlackField
Oscar
D110
This.
Old September 5th, 2016, 11:55 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
While certainly not the recommended method.. When mine was stuck on, I removed the set screw, removed the rear driveshaft, loosely threaded the nuts back on, locked the tcase, and took it for a 70 mph blast on the highway. Drum came off around 2 miles into the drive...
Old September 6th, 2016, 12:08 AM
RBBailey
RBBailey
1965 IIa
I've used heat and hammer and anger. Don't remember seeing another hole to thread a bolt into. There is a proper way to hammer a drum, but I can't remember exactly. Use a block of wood, and hammer the face? Or is it the sides? Can't remember...
Project:
1965 IIa SWB
Old September 6th, 2016, 07:59 AM
Matt_110's Avatar
Matt_110
Matt
110
BFH to the sides, and just outside the studs. Spray penetrating fluid anywhere you can first; around hub seal and each stud. You can also hit it from the back (giggidy) by placing another piece of metal against the lip and hitting that with a hammer. I've never heard of anyone cracking the drum by hitting it with a hammer. Not saying it's impossible, but I'd forego the wood.
1987 110, 2.8TGV, ZF Auto
Old September 6th, 2016, 08:05 AM
When hitting from the back, a wonda bar has been the best tool to position against the lip of the drum. Hit Hit Hit, rotate, repeat. Agree outside the studs and also on the outside of the braking surface. Hit Hit Hit rotate repeat.
After enough effort the SOB will come loose.
Old September 6th, 2016, 08:13 AM
Naplm00
Matthew
Balsy!
Big fucking hammer and annoying the neighborhood woks for me!
Old September 7th, 2016, 04:16 AM
jncilliers
Jaco
1988/110
Thanks for the advice! Ended up screwing a bolt into the threaded hole. A combination between that and a big hammer eventually made it pop off.
Nothing is ever easy is it.
Old September 7th, 2016, 05:19 AM
Huge congrats to you for your persistence.
Before you put it back on, remove the worst if the rust on the inside of the drum and smear some grease there
Series III Rear Axle (Drum-to-Drum or Axle Housing) Lriwater Wanted 0 September 7th, 2009 07:08 PM
Wanted E brake drum for and lt 230 TDI Guy Wanted 3 November 10th, 2007 12:45 PM
Problematic Brake Drum punter Defender Technical Discussions 8 December 1st, 2006 11:43 PM
110 drum brake shoes FS ECR For Sale - Parts 5 July 23rd, 2006 08:03 AM
D-90 rear drum brake axle assembly TDI Guy For Sale - Parts 0 November 6th, 2003 03:59 PM
