Stuck door tops - Defender Source
Old July 16th, 2008, 10:54 AM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Stuck door tops
Thought a search would pull something up, but.... I am trying to remove the door tops on my dad's '95 ST. He has owned it for about 3 yrs and they have never been off in that time. He did remove the nuts when he got it and replaced with the quick nuts off of his previous 90. Removed the quick nuts, but these tops are NOT moving. Tried tapping the bolt from underneath, and nothing. Also tried loosening liquid and nothing. Any ideas?
Thanks guys
"I race cars, play tennis, and fondle women, BUT! I have weekends off, and I am my own boss." - Arthur
Old July 16th, 2008, 10:58 AM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
I use a screw driver between the top and bottom and gently pry them apart.
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old July 16th, 2008, 11:12 AM
ctrover
jim larson
1984 v8 127
put an old nut on the very bottom of the bolt-same thread size-and give it a good whack with a sizeable hammer.The old nut will protect the bolt threads.Worked well on my old rusty series window tops.
Old July 16th, 2008, 11:29 AM
phoenix37's Avatar
phoenix37
john
just be careful not to hit the the door skin when you do it. My series has a nice set of "bubbles" on the outside of the door when i did the same thing.
Old July 16th, 2008, 11:41 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Ditto, I made that mistake too. Place a piece of metal between the stud and the skin to protect it.
Semper Fi!
Old July 16th, 2008, 11:58 AM
Grover's Avatar
Grover
Do not use a hammer directly on the door top studs...you will deeply regret it. Place a 2x4 under the stud and tap on it. Alternate between studs so the door top does not get cocked...
When you re-install it, spray waxoyl 120-4 or use axle grease on the studs to prevent further rusting...
Good luck...
Cheers...
Old July 16th, 2008, 01:17 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Take the studs out. Put two nuts on the stud and loosen them up. I wouldn't do any of that prying stuff. You'll just chip your paint or dent your skins (both of which I did and neither worked anyway).
Old July 16th, 2008, 02:57 PM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
What do you mean by taking them out Chris?
Old July 16th, 2008, 03:19 PM
Treuwer's Avatar
Treuwer
Trae Reuwer
94 D90
The door studs themselves are threaded into the door tops. The idea is to remove them from the bottom out so that the only thing holding the door top on then is the seal.
What I would do is hit up on the door top frame itself using a rubber mallet (so you don't dent the tracks). It seems like a less likely place to damage anything by hitting- no door dents but you have to be careful about the glass tracks.
Old July 16th, 2008, 03:37 PM
cellulararrest
Chris Snyder
Exactly what Trae said. They're threaded into the door tops. Once you remove the studs, there's nothing holding the door top on anymore.
Once you have the door tops off, you can thread the studs back into the door tops. It's a much less destructive way of getting them off.
Here's a thread about it... http://www.defendersource.com/forum/...t=stud+removal
Old July 17th, 2008, 09:11 AM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Ahhh. Thanks guys. We will give that a try.
Old July 17th, 2008, 09:13 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
also try a prybar.
Jimmy Buffett
Old July 17th, 2008, 09:16 AM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Originally Posted by flippedrover
also try a prybar.
That will be next. Hell, it's not my 90...
Also, being as lazy as I can, does anyone happen to know the nut size?
Old July 17th, 2008, 09:47 AM
15mm I think. Either 15 or 17.
And slide a putty knife between the seal and the door top to separate the two. Its amazing how well that seal with adhere the door top to the door when its stuck.
Old July 17th, 2008, 09:51 AM
cellulararrest
Chris Snyder
17mm feels right. I'd have to look. Just took mine off yesterday.
Old July 23rd, 2008, 01:09 AM
Raider's Avatar
Raider
Adam Knox
95 ST AA Yellow
I used wooden shims from Home Depot. After removing the nuts from the studs, I started at one end and tapped the shim in between the shim and the door bottom using a rubber mallet. Then I started another sim a couple of inches further up...and so on and so forth.
Do NOT use a piece of string and try to pull it through the door and the seal. It leaves unsightly marks in the paint that don't buff out.
Old July 23rd, 2008, 09:21 AM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Good idea with the shims Adam. I just happen to have some. That soft wood will probably not do any damage either?
We have not had a chance to work too hard on it, but my dad just retired down here from TN and really wants them off. He plans to keep it topless in the garage and actually start using it (currently has 15k miles). For all we know the tops have never been taken off...
Old July 23rd, 2008, 09:51 AM
paulb's Avatar
paulb
Paul / Boultbee
1994 D-90, Green #1576
This is so funny - I did the same thing everyone else did - go slow and careful and use lubrication. My fav is Triflow that I get at the mountain bike shop.
But once you do get the door tops off, my question to you and all, how did (and to you Burke how will you) get the plastic slieves back into the tunnels where the bolts go for when the tops go back on? Mine do not fit, I even bought replacements from RN and still can not get them into place. Right now I jut put the tops back on without them but they do wobble a bit.
I'm contemplating thinking about thinking about it!
Old July 23rd, 2008, 11:50 AM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Interesting.... When messing with my dad's 90 I thought there was a difference from the doors on my '94. I do not have the sleeves either (and never have)... I can get mine tightened down ok, but not all the way. I have been running for 14 years that way so I guess we are ok Paul
Old July 23rd, 2008, 11:04 PM
hutch's Avatar
hutch
Hutch
97 AA Yellow D90 ST
I managed to dent the door from the inside out using a hammer on my 95 - definitely avoid it. It's the tacky rubber that has more or less glued itself. What I did with my 97 was take silicone lubricant and sprayed it at the rubber and let it sit. Then with the window slid open I applied upward pressure on the top of the door tops from the open portion of the window. Hold the pressure there for 30 seconds to a minute (yes it's hell on your back) but what I found it that it eventually will start to separate - ones it does you are golden. You may need to do that few times - you'll feel like nothings happening but then it should separate. Mine peeled the paint off a bit but better than damaging the aluminum doors.
Hutch
door, door tops
D-90 stuck in Park, Won't start. HELP!!! brianosaurus Defender Technical Discussions 9 December 12th, 2007 09:45 AM
Help - Stuck in water for 3+ hours mfreeman17 Defender Technical Discussions 2 May 25th, 2005 08:10 AM
Brake Lights Stuck ON RoverWrecks Defender Technical Discussions 4 August 21st, 2004 11:26 AM
Stuck In Iraq javelinadave Misc. Chit-Chat 5 April 12th, 2004 07:53 PM
Stuck in the River! wicks Misc. Chit-Chat 0 February 2nd, 2004 04:27 AM
