STUBBORN xfer case fill plug - Defender Source
Old October 11th, 2014, 07:13 PM
doscazadores
Vic Stull
none
'94 D90
Fill plug on the xfer case won't budge, though I was afraid to apply much torque until I posted here. There are a 2-3 green flecks near the hole so maybe someone applied Loc-Tite to the threads when it was last serviced? This obviously needs to be remedied as I'm thinking it should be refilled before driving it any distance. Not to mention next Friday's 500+ mi. round trip into the Mojave for opening day quail/chukar. :-)
Anyway, I'm open to guidance. Thanks
Vic
Old October 11th, 2014, 07:28 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I don't think you can do any damage to the case itself. Sounds like someone added loctite or over tightened it.
Just remember rightie tightie leftie loosie and add a breaker bar. Go slow.
Semper Fi!
Old October 11th, 2014, 07:40 PM
doscazadores
Vic Stull
none
Thanks. Got it by applying a propane torch flame to it for about 15-20 seconds and then it broke free relatively easy. And there was Loctite on the threads.
Old October 11th, 2014, 07:43 PM
Loctite should be red or blue. I wonder if it's some attempt to seal up a leaky plug.
Transfer case fill plug Viton Defender Technical Discussions 3 February 20th, 2013 10:07 PM
Drain Plug Diffs/Xfer Case Grover Defender Technical Discussions 7 November 11th, 2009 11:21 PM
Xfer case Fail Abrooks Defender Technical Discussions 17 March 31st, 2009 10:00 PM
WTB: D1 Transmission and Xfer Case PCRover Wanted 9 March 14th, 2008 11:11 PM
EMERGENCY-Xfer case issues Cyborg Defender Technical Discussions 7 July 18th, 2004 02:50 AM
