stub axle oil seal - Defender Source
Old January 26th, 2015, 02:07 PM
CMorrow89's Avatar
CMorrow89
Chuck Morrow
97/Defender 90 # 378
stub axle oil seal
I got around to replacing my rear brakes (97 NAS) and rotors. With disassembly i found about a cup of what i assume is differential oil. I researched it and found some differing opinions on the need for replacing the stub axle oil seal. Anyone have experience good or bad with leaving it alone.
Old January 26th, 2015, 02:09 PM
You dont need it, the paper gasket on the axle is all you need. If you to make axle removal a bitch you can use RTV around the drive flange
Salisbury Axle with a welded on stub axle, disc brakes, Factory? Capt Milks Defender Technical Discussions 5 December 21st, 2010 09:45 AM
Stub axle bolt SIII bcourtney Defender Technical Discussions 11 March 10th, 2010 07:13 AM
Axle stub shaft intermediate seal cgalpin Defender Technical Discussions 8 July 21st, 2008 07:33 PM
Stubbed... stub axle bearings and seal thewap Defender Technical Discussions 2 June 29th, 2006 08:07 AM
Stock stub axle assembly thewap Wanted 0 June 28th, 2006 08:01 PM
