Stub Axle Bronze Bush - Defender Source
Old June 7th, 2010, 09:50 AM
MAX711's Avatar
MAX711
Andrew Dance
1994 D-90 ST
I can't seem to find a part number for this bronze bush. Does it come as part of the stub axle? It's the front stub axle off a 94 Defender.
Also, any tips on how to get that bearing out without the special tool?
Old June 7th, 2010, 10:07 AM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
I wouldn't mess with either of them. Grease them up and put them back in service. The bearing will be fine if you knock it out from the other side but the seal will die.
Keith
Big, Red and ... aaa Red..
Old June 7th, 2010, 10:14 AM
MAX711's Avatar
MAX711
Andrew Dance
1994 D-90 ST
I should have mentioned, the reason I was looking for the bronze bush is because the stub axle needs replacing. A wheel bearing must have seized at some point in the past and the stub axle is pretty badly scored.
Old June 7th, 2010, 10:34 AM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Call Will Tillery and get a nice used one for cheap. 434-251-9331
Keith
Old June 7th, 2010, 10:35 AM
I have a slide hammer pilot bushing puller that will get those out but it is technically too small so it kind of requires two people. Surely there are other fittings that would make it work but I've yet to have occasion to look for them. Not sure what the function of the bronze bushing is but I think it runs against the face of the CV's bell. You might try heating it in an oven and then popping it off with a homemade mild steel chisel. it might need some cleanup on the outer edge after that operation but I don't think that is the working face so it shouldn't matter.
If you make the chisel flat on one side and place that side toward the bushing it should work and any damage will be to the stub axl which you are discarding anyway.
Or call Will Tillery like Keith said
Old June 7th, 2010, 11:01 AM
Just buy a used replacement.
Old June 7th, 2010, 03:34 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Depending on how badly and where it's scored you don't really need to replace it. I had one that was so seized that I had to use a bearing puller to get the inner hub bearing race off. I cleaned it up and the new bearing fit fine so even though I'd bought a new one, I didn't replace it. That was about 8 or 9 years ago and I haven't had any issues with it.
Of course if the distance piece is scored you need a "new" stub axle. Land Rover, in their infinite wisdom, made the distance piece so it can't be replaced.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old June 7th, 2010, 04:26 PM
MAX711's Avatar
MAX711
Andrew Dance
1994 D-90 ST
What do you mean by the "distance piece"?
Old June 7th, 2010, 06:08 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
x2... Use a slide hammer with the small jaws to grab the bearing. Pops it right out.
Legend in My Own Mind.
Old June 7th, 2010, 09:34 PM
Antichrist's Avatar
Antichrist
Tom Rowe
The distance piece is the raised part the seal rides on. It's called a distance piece, at least on Series Rovers because the hub bearing inner race seats against it to locate the hub.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
axle
Seal at axle tube/swivel ball snuffer Defender Technical Discussions 8 February 7th, 2011 05:06 PM
Complete HD Salisbury Rear Axle For Sale Northface For Sale - Parts 4 July 21st, 2006 08:29 PM
Stubbed... stub axle bearings and seal thewap Defender Technical Discussions 2 June 29th, 2006 08:07 AM
Stock stub axle assembly thewap Wanted 0 June 28th, 2006 08:01 PM
new rear axle rolaro Defender Technical Discussions 8 January 26th, 2005 11:34 AM
