Stromberg carbs oil help - Defender Source
Old January 16th, 2016, 01:37 PM
Landyman1's Avatar
Landyman1
Landyman
1983 land rover 110 county
I need to top up my Zenith stromberg carbs with fluids (they're pretty dry) as I have not really ever done that. Anyways, some people recommended I use ATF but the automatic transmission fluid I have is castrol transmax DEX/MERC ATF. Is this fine or should I use the sae10w-40 motor oil I have lying around. Thanks
Old January 16th, 2016, 02:21 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
20w I do believe, that's what I have always used in my old su's
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old January 16th, 2016, 03:00 PM
Departing90
Sasha
95 D90
ATF for winter & 20W for summer. If you use the ATF for summer it'll "thin out" too much and vice versa.
Old January 16th, 2016, 03:08 PM
Then why not use a multi weight like a 0W20?
Old January 16th, 2016, 04:21 PM
Departing90
Sasha
95 D90
Because even the "0" in 0/20 is not as thin as ATF if your engine runs good with ATF I suspect due to inevitable tolerances in carbs.
That aside marvel mystery oil is better than both for that application! It has the correct consistency and will keep the carbs clean & clean out your valves to boot! Additionally and more importantly its not affected by temp changes!
what carbs ? Uncle Douglas Defender Technical Discussions 37 August 4th, 2015 07:50 AM
1984 Defender Intake and Ex. manifold and weber dual carbs bstraw For Sale - Parts 4 December 19th, 2011 08:00 PM
twin su carbs needed draaronr Wanted 0 July 20th, 2010 09:10 PM
1983 110 3.5 carbs tentoesjoe Wanted 1 September 24th, 2009 03:24 PM
Twin carbs and manifold kellymoe For Sale - Parts 2 July 29th, 2004 01:12 PM
