Stripped Transmission Filler-Plug - Defender Source
Old February 19th, 2011, 09:38 AM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
Hello my D90 brothers...
It's been a while. Just had my 9th anniversary with my Defender...
I have been neglecting the vehicle by having someone else work on it. These IDIOTS in town called DERMEISTER... don't even get me started.
In any case... The head IDIOT mechanic tightened down the manual transmission (1995 NAS D90) filler plug to no end and when I went to check the fluids, like I have been doing for 9 years, give or take... I stripped it. I'm so pissed. I've never stripped an inside plug like that and I don't know how to get it out.
I'm guessing I'm going to have to buy a new one.
Can anyone help in telling me how I can get that out? My mistake may have bee using an 8mm allen wrench... But it's been fine all this time.
Thank you.
norros
Nicholas Orros
Tallahassee, FL
Old February 19th, 2011, 10:08 AM
CMS3900
Morgan
1974 SIII 109
did the allen part strip or did the threads strip? if the allen part stripped you have three decent options. First is put a nut over it and weld the inside of the nut to it and remove it. If you don't have acess to a welder, you will probably have to drill a hole through it and use a big easy out. Start with a high quailty drill bit and try it slow with coolant, if it dosen't cut a cheap trick is using a small masonry bit becuase its carbide tipped. Once you have a hole and a easy out it should come out. The third is if its proud of the transmission case you might be able to finesse it out with a small sharp chisel and a light hammer. a little heat might help too becuase aluminum expands alot faster than steel.
Old February 19th, 2011, 10:41 AM
Naplm00
Matthew
If there is enough room I usually hammer a torx socket into the filler plug. Then hit the surrounding metal with the mapp gas torch. Worked on all but one
Old February 19th, 2011, 11:38 AM
newfD90's Avatar
newfD90
Chance
93 NAS 110
There 'ya go. It's a Torx T-32, I think. The allen wrench will work until the monkeys tighten it too tight, then you round it out. Mine was this way just recently when I went to put Redline in. I bought the correct Torx socket and hammered it in. Patience; it'll come out.
Chance
Old February 19th, 2011, 02:53 PM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
I figured it was something else as I could never see it and that worked fine. Well, off to Lowe's.
I like the weld idea and I actually just bought a TIG welder and am in the process of learning... Test #1 isn't going to be a cramped corner like this though.
Much appreciated.
Old February 19th, 2011, 06:08 PM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
It's not a TORX 32... I put a TORX 50 in there and it wouldn't even touch... That is all they had at Lowes.
I'm going to order another filler plug then go from there. I'll probably bring it somewhere. AHHH!!!!
Old February 20th, 2011, 10:22 AM
newfD90's Avatar
newfD90
Chance
93 NAS 110
Damn, I'm an idjit. I just went and double checked. I don't know WTF I was thinking when I typed T32. It's a T55. Sorry man. Mea culpa.
Chance
Old February 20th, 2011, 11:18 AM
T55 torx. They have them at Sears under the isle [sic] brand in a three pack.
Order a normal internal or external 1/2in square plug to replace it.
Old February 20th, 2011, 11:35 AM
seriousactualist
Paul Martin
1995 D90 ST
Lisle. Some good stuff from Iowa.
Sure hope the plug comes out without much further fussing!
Old February 21st, 2011, 04:34 AM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
It's cool... I went and got a Torx55 yesterday but didn't have a chance to mess with it but later this afternoon hopefully it comes out.
The other thing I need to do is order me a new transmission filler plug. I will probably just go the usual AB or RoversNorth route... Unless someone has a better idea.
Thank you brothers for your responses.
nasd90
Old February 21st, 2011, 09:35 AM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Something to consider, the filler is 3/4 NPT plug, you can go to the hardware store and buy a hex head plug in brass. There are a coupe benefits, first the monkeys at the lube store will understand it, it's cheap and it doesn't require a special tool to remove it
Keith
Big, Red and ... aaa Red..
Old February 21st, 2011, 04:28 PM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
Well, it came out rather nicely with a TORX55, though I will need a new plug regardless.
It's not a 3/4 plug... wayyyy too big. Luckily when I pulled the plug there was plenty of transmission fluid in it, enough to get all over my arm. So, I am probably just going to order one from my original sources.
Thanks again fella's...
Old February 21st, 2011, 04:30 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Don't forget the "NPT" part.
Keith
Old February 21st, 2011, 04:32 PM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
I see... I showed the guy at ACE Hardware but he was a monkey and gave me something else I imagine.
I read on another board that it's a 32mm torx plug. I'm confused.
Old February 21st, 2011, 04:38 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
It could be bigger and could be British straight pipe thread, but for what it's worth an NPT plug will fit, it's best if it's brass.
Keith
Old February 21st, 2011, 07:31 PM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
It's actually much smaller than 3/4... I don't think it was just the threads that were off. the whole plug that is on my truck right now is smaller than 3/4. I'm guessing NPT is the thread size correct? I never had to mess with this so I have no idea.
Thanks for the attention bro.
EDIT: I just looked up NPT... I get it. I'll have to go searching tomorrow I guess.
transmission, trip
Transfer Case Filler Plug removal d90xjay Defender Technical Discussions 19 December 29th, 2009 12:56 PM
Stripped spark plug threads in the heads Hans Defender Technical Discussions 0 November 8th, 2009 07:41 AM
what does this plug in to? mattdh Defender Technical Discussions 6 November 2nd, 2004 11:59 PM
Adding a Side Tank - Alternate Filler Method JimC Misc. Chit-Chat 6 October 25th, 2004 12:29 PM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 01:42 PM
