Stripped transfer case drain bolt - ideas to remove/fix? - Defender Source
Old October 1st, 2015, 04:11 PM
mmdcomm
Matt
1985 Ex MoD 110
Hi all - I stripped the drain bolt on my transfer case while trying to remove it. It rotates either direction now but isn't coming out.
I'm here with Loic, who graciously offered to help me, and we've removed the plate from the transfer case with the thought that would give us the ability to press down on the drain bolt and get it out that way, but the gears make that a nonstarter - they're in the way.
Any ideas on how to proceed? The case looks good (and of course) the oil looked good too before we removed the plate).
I'm thinking I play it safe, put the plate back on, refill the oil and skip MAR (sadly) and fix the bolt in the near future. When there isn't a hurricane coming through town, for example.
Thoughts?
Old October 1st, 2015, 04:23 PM
That sux. I would consider clamping the bolt with vise grips, then drilling a hole in center of bolt head and drilling the bolt out by increasing in size. you could also just thread that hole to the size of an slide hammer, then pull it straight out that way.
once out, thread the hole to then next larger size and put a new larger bolt in to seal it.
Mark Kellgren
KM4BOR
Old October 1st, 2015, 04:28 PM
I would spin it until there are no threads left, then try pulling it out with vice grips. The other option would be to wedge a prying tool between the bolt and the case, and try to loosen it while you pry on it.
Old October 1st, 2015, 04:33 PM
Naplm00
Matthew
can you fit a screw driver behind the face from the outside? pry up HARD while turning
Old October 1st, 2015, 04:48 PM
Naplm00
Matthew
or just grind the head off and pound it into the case so it pops through. then put in an oversized plug from autozone
Old October 1st, 2015, 07:35 PM
carlosz's Avatar
carlosz
Carlos
Remove and helicoil to repair threads.
the truck ran like a "raped ape"
A fussy warm weather creature...
Old October 1st, 2015, 08:18 PM
Removing it is his first problem.
Old October 1st, 2015, 09:01 PM
mmdcomm
Matt
1985 Ex MoD 110
It does suck, and it's made more frustrating by having only myself to blame. Damn you, inflated sense of self-reliance!!
We tried to get a screwdriver under the nut / washer from the outside, and pulling while turning the nut, but no luck. And there was no way at all to get any pressure from the inside once we had the plate off because one of the gears is literally right above where the bolt sits in the case - could barely get the screwdriver in there.
I think this is where I am now, that there are no threads left. We thought about cutting the head off, but I think I will try vise grips first. I don't want to leave anything in, which cutting or grinding would do. If vise grips don't work, cutting/grinding/drilling is up next I guess.
I'm a total noob so if you have time to elaborate, I'd really appreciate it. I think the issues (generally) are (1) get the stripped bolt out, and (2) get a new, working bolt in. I know the devil is in the details but is this the right track? I definitely accept that this is not an immediate-fix process...
I was pleased to see that the gears, plate and oil looked good anyway. I think Loic and I removed the original paper gasket today too. It was all pretty cool to see, though I would've preferred seeing it on a youtube instructional video instead. Live and learn.
Help: stripped clutch slave cylinder bolt hole ontheway Defender Technical Discussions 6 September 2nd, 2015 07:48 PM
Broken transfer case drain plug jefhuf Defender Technical Discussions 12 August 8th, 2012 09:16 PM
Did I strip my Transfer case drain plug? J. Andrew Defender Technical Discussions 11 March 31st, 2011 12:32 PM
Transfer Case Drain Plug Problem kzack Defender Technical Discussions 10 October 21st, 2010 08:14 AM
Stripped bolt-head issues. devinchi Defender Technical Discussions 1 September 7th, 2007 04:47 AM
