stripped lens screws? - Defender Source
Old July 10th, 2007, 03:24 PM
Caribsurf's Avatar
Caribsurf
Donald McDowell
Black 1997 D-90 soft top
Location: Delray Beach, FL/ Bequia, St.Vincent & Grenadines
I did a search on this and found nothing so here it goes...washing my 97 D-90 over the weekend I noticed that a couple of the lenses (rear left brake light and front left indicator) were loose. I grabbed a phillips head and tried to tighten screws but found they wouldn't tighten and just kept spinning round and round . Before I try and remove the lens to check it out inside wanted to check here first. I imagine these screws attach to something inside....maybe that part is stripped?
Thanks in advance
Old July 10th, 2007, 03:27 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
If you don't want to change the plinths (the black things) get a heat source like a soldering iron and melt some plastic back into the holes. Then put the screws in. They don't need to be very tight (otherwise it strips the plinths)
Email:
Old July 10th, 2007, 03:36 PM
Caribsurf's Avatar
Caribsurf
Donald McDowell
Thanks Mike sounds like the pliths are fragile so my guess is mine are stripped. Good idea about filling the holes some...
Old July 10th, 2007, 05:20 PM
GYM's Avatar
GYM
Gary
97 SW
...or alternatively, call George @ RDS...... $8.00. # AMR3850.
Old July 10th, 2007, 05:42 PM
Caribsurf's Avatar
Caribsurf
Donald McDowell
Thanks Garth I did see the part on RN and AB websites seems like an easy fix, but with my luck the old Plinths will be fused on and might be a bigger problem than it currently is.
Will have to check and if they will come off easy I will order replacements fortunately I only need two.
trip
1/NEW NOW NAS110/94D90 White Reverse Reflector Lens and Clear Lens Cover- $50.00 NashvilleRover For Sale - Parts 5 November 4th, 2009 10:48 AM
Light Lens Renew FYI Kimos Defender Technical Discussions 6 December 7th, 2004 12:06 PM
Clear lens for running lights PT94D90 Defender Technical Discussions 5 April 9th, 2004 07:28 PM
Stripped nuts on the driveshaft... dmarchand Defender Technical Discussions 13 November 18th, 2003 09:41 PM
Rear Door Hinge Screws Rob Defender Technical Discussions 1 October 12th, 2003 06:46 AM
