Strike plate removal oops - Defender Source
Old August 10th, 2015, 09:56 PM
aosias's Avatar
aosias
Alexandra
1995 D90
I removed the front door on the 110 to replace the latches and the new ones I installed needed to have some washers taken out from the strike plate to line them all up. Easy enough. In the process of removing the strike plate I dropped the plate that has the nuts attached in the abyss of the T-support.
I can see it in there but can't get it out. Ideas on how to retrieve this?
Old August 10th, 2015, 10:06 PM
As the old workshop manuals say, removal is the reverse of refitting..... .... Every tool box should have these
Sears.com
Old August 11th, 2015, 06:51 AM
flananuts
Matthew
LRC Customs #003 D110 Soft Top
Couldn't agree more. I had to use mine with the assistance of my go pro and a flashlight for retrieval because I wasn't able to see with the naked eye. Another great trick is to get a gel form of super glue for non metallic parts. Just press into the part, count to 10, and retrieve away.
Old August 11th, 2015, 07:45 AM
With a big magnet you can walk it up from the outside
Old August 11th, 2015, 09:02 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Another great tool is the smallest Gorillatorch. You can laydown a beam of light on every nook and crevice. This works where a shop light or head torch does not. Magnetic feet as well.
Strike Back Burke Misc. Chit-Chat 3 August 27th, 2012 03:39 PM
Prop shaft removal oops Broncoduecer Defender Technical Discussions 55 August 20th, 2012 11:34 AM
SW door strike plates Crash303 Wanted 0 October 1st, 2010 11:34 AM
Door Strike Plate Bolts xrover Defender Technical Discussions 0 September 27th, 2008 12:03 AM
