Strange Warning Light - Defender Source
Old June 15th, 2007, 12:00 PM
jordan0527's Avatar
jordan0527
Jordan
97 D90 ST, 04 D2
I searched the forum and found this post by a member who hasn't been active in over two years. There was never a response with a solution, and now I have the exact same problem:
"The other day I came home after it had rained a fair amount (I actually washed my truck) and there is an ongoing clicking sound in the truck now. The warning light for what looks like a rear windshield defroster lights up alongside a wierd clicking sound (electric shorting or something). Oddly enough it only starts making the noise when I open the door or move the truck at all. Any ideas? I think it must be electrical. The clicking sound is coming from the console area, anywhere from the Fuse Compartment to the gear box. "
Anyone know what causes this and how to fix? Thanks.
Old June 15th, 2007, 12:07 PM
sounds to me like the relay to the rear window heater got wet, and sloshing water in something causes it to heat up and trip.
Old June 15th, 2007, 12:16 PM
jordan0527's Avatar
jordan0527
Jordan
97 D90 ST, 04 D2
It's a soft top...no rear window to heat
Old June 15th, 2007, 12:17 PM
Caribsurf's Avatar
Caribsurf
Donald McDowell
Black 1997 D-90 soft top
Location: Delray Beach, FL/ Bequia, St.Vincent & Grenadines
no the clicking problem has to do with the anti theft system I had the same problem and researched it.
see the attached below....
Antitheft System - Dash Area Clicking Noise
No:
86/03/98/NAS
Ref:
WSM Section 86
Issue:
1
Date:
07/17/98
Clicking in 10AS Control Unit
AFFECTED VEHICLE RANGE:
DEFENDER (LD) VA992105 to VA999484
VA100300 to VA126471
SITUATION:
INTERMITTENT CLICKING NOISE FROM DASHBOARD
An intermittent clicking noise may be heard coming from the dashboard on some '97 model year Defenders. The clicking noise sounds very similar to a turn signal flasher in frequency and loudness. Once the clicking noise begins, it will continue until the ignition switch is cycled off and then on again. The source of the clicking noise is a relay within the immobilization control unit (10AS unit). A revised unit is now available to address this symptom.
RESOLUTION:
REPLACE IMMOBILIZATION UNIT
To address a customer complaint matching the above description, verify that the source of the clicking noise is the alarm ECU and replace the unit with the latest type.
PARTS INFORMATION:
AMR6430A Immobilization Unit
WARRANTY CLAIMS:
86.77.01 Time 0.70 hrs.
Replace 10AS ECU
FAULT CODE: Z
Normal warranty policy and procedures apply
REPAIR PROCEDURE:
REPLACE IMMOBILIZATION (ALARM) CONTROL UNIT
1.
Refer to the procedure in Workshop Manual Section 86, Page 16, Operation 86.77.01.
2.
Remove the 10AS unit from the vehicle.
3.
Install the new 10AS (AMR6430A) and initialize with TestBook.
Old June 15th, 2007, 12:24 PM
jordan0527's Avatar
jordan0527
Jordan
97 D90 ST, 04 D2
Wow...I had no clue the truck even had any type of anti-theft system (other than the Alpine alarm I had installed). Donald, did your rear window defroster light illuminate when you had the problem? How much did it cost to replace the alarm control unit?
Old June 15th, 2007, 12:27 PM
Caribsurf's Avatar
Caribsurf
Donald McDowell
I have a soft top so no rear defroster Actually I never had the issue resolved. The clicking happened one time after getting caught in the rain and never happened agaian. I drive with the surrey top on now so avoid most rainy days. Apparently it has to do with a part getting wet. It isn't a big deal I don't think just annoying but you can stop the click by turning on/off ignition
As you can see in the information Land Rover was/is aware of the problem.
good luck
Old June 15th, 2007, 02:07 PM
D90DRC
D Cantrell
1997 D90SW
Yep i have the same issue but fixing it is so far down the list it will most likely never happen...
Old June 15th, 2007, 07:00 PM
Caribsurf's Avatar
Caribsurf
Donald McDowell
my thoughts and plans exactly
ht
how many forum members does it take to change a light bulb? brn24whl Misc. Chit-Chat 14 December 4th, 2009 09:07 AM
Intreior Light Problem proulx70 Defender Technical Discussions 3 February 7th, 2007 05:30 PM
Blinking brake warning light D90user Defender Technical Discussions 15 September 4th, 2006 06:20 AM
Light disaster! rustydefender Defender Technical Discussions 11 December 30th, 2005 03:34 PM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
